305 engine
Old May 25, 2008 | 10:15 PM
aged 86 transam's Avatar
Car: 1986 trans am
Engine: 305 with almost 2000000 on it!!
Transmission: 700 r4
305 engine
hey i have looked around on this section and everyone is telling engine swappers to go from a 305 to 350's i am beginning to look into it and i am not a horse power junkie, just want my trans am to live up to my name! i found a 305 on ebay for under 1000 but would like to hear what u have to say, weather the 305's are bad or people just don't perfer them
Old May 25, 2008 | 10:39 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Re: 305 engine
The 305 is a great engine. It's also a good starter V8 imo. What will you be using the car for? I prefer to cruise in my 305, and if I wanna run I'll take my dad's 350 IROC. Not saying the 305 can't move.
EDIT: Plus you can always bore out and stroke the 305, make a 334/335 why not?
Old May 26, 2008 | 01:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Because it's a stupid waste of performance $'s.
Old May 26, 2008 | 08:14 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Re: 305 engine
305's are fine. But you can get more bang for the buck using a 350 as a base instead of a 305. You can get a 305 to come close/match a 350 but your most likely to spend more to get to that same point.
What point do you want to get to though? With the price of gas these days, maybe you'd prefer the 305's slightly better mileage?
Old May 26, 2008 | 11:00 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Re: 305 engine
Personally, I like the 305's. I like 350's a little better, but I never find deals on them around. So I just did a 305 to 305 swap cause a 305 suits my needs for now. I don't think you should be paying near 1,000 though.. unless its low miles, or really pumped up. Have you checked craigslist? There are always good deals on that. 95% of the guys on the forums will probably tell you that a 305 wouldn't be worth it if it was free. but don't listen to them, the 305 is underestimated i think.
But if you indeed get the 305...and you DO want more power.. let me know.. if found an INCREDIBLE article in a camaro magazine telling you how to cheaply pump the 305 up to blow a 350 away. Its a GREAT article
See ya!
-Andrew
Old May 27, 2008 | 12:56 AM
five7kid's Avatar
Originally Posted by wshbrn91
... found an INCREDIBLE article in a camaro magazine telling you how to cheaply pump the 305 up to blow a 350 away. Its a GREAT article
What 350 were they comparing it to, a '79 Caprice?
Statements like that are just plain silly. Spend the same money on a 350 and you'll blow the 305 out of the water.
Old May 27, 2008 | 01:03 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 305 engine
small block chevys share so many parts and the cpl parts that are different cost about the same (i.e. piston sets) the most affordable way to make power is to go with the o so common 350, more displacement and most common sbc for aftermarket parts... so when it comes down to it if it costs roughly the same for a 350 y not upgrade.....
Old May 27, 2008 | 06:48 AM
Car: 1986 trans am
Re: 305 engine
well thanks for all your replies!!!! i will keep looking and if i find a deal on a 350 i might take it because the manifolds fit both right? but if nothing else so far with how crappy my 305 is running right now i am still satisfied, the car is going to be a weekend project car and besides i can take the motor in it now and toy with it with performance parts later on if i like. i will keep my eyes and ears open
Old May 27, 2008 | 03:05 PM
five7kid's Avatar
See sig. Everything that is on the 350 now was previously on the 305, including the heads.
The difference in 1/4 mile ET was over a second.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
