No air from vent - only defrost
Old Jun 2, 2008 | 10:46 PM
bullzz's Avatar
Car: 1984 Trans Am, 2003 Z06 Vette
Engine: zz383
Axle/Gears: 9" moser 3.70
Hi,
I recently swapped a 305 engine with a crate zz383 and am in the process of rewiring everything. I am not using the ECM anymore but left it in place for a few of the gauges. With the engine swap I decided to do away with the AC. Now when I turn on my heat, I only get air blowing out of the defrost and not from the front or lower vents. I still have the original wiring harness in place. Is there something I need to connect? The car is a 1984 trans am.
Old Jun 2, 2008 | 10:47 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
Re: No air from vent - only defrost
there might be stuff in the fan blower, when i took mine out to replace it there was a rats nest in mine....
Old Jun 2, 2008 | 10:55 PM
bullzz's Avatar
Engine: zz383
No way! I hope I dont get attacked by some rabid rat.
It looks like the control switch is electronic and not mechanical thats why I figured the problem was caused by not reattaching the AC and the wires that were attached to it. Damn car had like 5 miles of tubes and wires. I dont know how I ever thought that car had power. I guess it did for its time...
Old Jun 3, 2008 | 02:01 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're missing the vacuum line that goes from the engine to the EVAP controls inside the car. I'm not sure where it is on an '84 f-body, but on my car its a plastic line inside the wire loom that sticks out by the rear passenger side of the engine. Its supposed to connect to a vacuum port on the intake manifold.
Old Jun 3, 2008 | 09:29 PM
bullzz's Avatar
Engine: zz383
I see the plastic line but no longer have a vacuum port to connect it into. Is there a way to bypass this? Is the vacuum port powered? As I recall, I was able to switch from vent to heater to defrost with power from ignition and the engine off.
I also eliminated the smog pump - actually everything from the original engine.
Thanks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scottmoyer
Sep 7, 2015 07:06 PM
TBRays98
Sep 6, 2015 05:05 PM
