biggest engine for a camaro
Old Sep 17, 2008 | 12:02 AM
sjcrazyjuggalo's Avatar
Car: 92 camaro RS
Engine: v8 305
what is the biggest engine you can fit in a 92 camaro. I thought it was a 383 but i just seen on here some one said on there specs they had a 402.
Old Sep 17, 2008 | 12:09 AM
Stephen's Avatar
Car: 87 GTA
Re: biggest engine for a camaro
There really isn't "limit" on what will physically fit...A 514 big block will fit...Legally? No...,but it'll fit. Granted, a scoop will be required for intake clearance, but it'll fit.
Now...Legally?
Gen 1 block...406 small block...
LT, same...
LS....I've seen 472s, but I'm not sure the life of those & don't wanna know the life span!
Old Sep 17, 2008 | 12:12 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you can fit any engine in your camaro.. its just how much do you want to spend.. just because the displacement number is high, doesnt mean the engine is physically big.. anything from a 283 to a 421+ is the same physical size.. read up about chevy engines before you get yourself into a pickle with engine stuff..
theres alot of things that you can learn from magazines.. go to the store and pickup a chevy car mag.. car stuff is like any other hobby.. you dont want to fight in the UFC if you dont know anything about it..
Old Sep 17, 2008 | 08:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All SBC engines are the same size externally so any size SBC will fit. You can also drop in any short deck BBC. A tall deck BBC takes a bit more custom work.
I have a 540 BBC in mine but it's not street legal.
Old Mar 3, 2021 | 11:24 AM
jacobm92's Avatar
now why is it not street legal? is there a horsepower regulation or will it not pass inspection?
Old Mar 3, 2021 | 02:25 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Pretty sure he has a track only car. Every state has different laws, inspection, emissions, etc.
Somebody was doing a viper V-10 swap. Not sure if it ever got finished? But a big block will fit in there fairly easy.
Old Mar 3, 2021 | 08:22 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
there are 3rd gen's out there with 959 cubic inch engines. the actual cubic inch number is INTERNAL, the physical size of the engine is either small block, big block, v6, v10, etc etc
84CAMARO28inFL
Mar 1, 2011 08:07 AM
87GTACamburke
Jul 6, 2008 03:03 AM
CamaroRS385hp
Jun 29, 2003 10:09 AM
berklified
Jun 10, 2003 10:23 PM
89' RS/blue
Mar 18, 2003 10:16 PM
