Replacing Engine.
Old Jul 3, 2008 | 10:43 PM
87GTACamburke's Avatar
Car: 1986 Pontiac Firebird
Engine: 305 4bbl
Replacing Engine.
Hey guys,i was just wondering,whats the biggest engine you could fit into a 1986 Trans Am,with out messing with the frame or anything else.
thaks.
Old Jul 3, 2008 | 11:11 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: Replacing Engine.
Probably a small block. [so 350 or 400, then theirs stroker motors too]
but wait for someone more experienced to chime in.
Old Jul 3, 2008 | 11:21 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
This is not specific Aftermarket Product Review so I am moving it.
Personally, if money was no object, I'd look at building a 427 with custom EFI, but that is just my opinion. Budget and ability would be everything, though.
Good luck.
Old Jul 3, 2008 | 11:28 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
big blocks fit, stick with a built small block and save the headache. if your hell bent on a headache then go for the ls engine route. Im asuming you dont know much about engines so we will be here for all your quearions but i do advise to search first.
Old Jul 4, 2008 | 07:33 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
It's what I did before deciding on a motor. Check out what other people have swapped in and take note of what they had before. It's different for each case.
In any case, maybe to more direct your post I think you want to know how much HP/Torque before you have to start thinking about subframe connectors, etc. This will narrow down your engine search.
Would I be correct in saying anything over 250 HP/Torque you should start upgrading the body? Just as a ballpark figure.
Old Jul 4, 2008 | 08:55 AM
Engine: 305 4bbl
i know some what about engines,but i wouldnt trust myself rebuilding one without somones help haha,jus getting into it ya kno,and Trans Am is my favorite car next to a 1970 Chevelle SS.
Old Jul 5, 2008 | 07:28 PM
irocz436's Avatar
Car: 87 irocz
Engine: 436 chevy sbc
Transmission: th 400
Axle/Gears: 373
i istalled a 436 chevy sb in my irocz 600hp ,630 ft lbs. and all i did was put sub frame connectors in.if you have t-tops you should have them it eliminates all the rattles .
Old Jul 6, 2008 | 03:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
These cars need subframe connectors even if they have a V6.
The question is really too open-ended to even hazard a guess. "What's the biggest..." or "What's the most..." or "How fast can..." are impossible to answer. Simple things like budget and what you're planning on doing with the car need to be known up front before any reasonable response can be expected.
gta90
Sep 15, 2015 04:00 PM
Bryan F
Aug 18, 2015 02:28 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
