351w swap
Old Nov 16, 2008 | 05:03 AM
proxemics's Avatar
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
351w swap
hi
I found a race ready 422 sbf (351w stroker) that run 9' in fox body stang the owner sold the car as a roller and now he wants to sell the engine and I'm thinking about dropping it in my Z28
is it alot of work to do or just engine mount and headers to figure out !!?
Old Nov 16, 2008 | 06:34 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 351w swap
WHAT ???? PLEASE TELL ME I READ THIS WRONG !!!
Old Nov 18, 2008 | 01:56 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 351w swap
being serious, I'd like to see you try it. I think it'd prove easier if you use a fabricated tubular crossmember, and while using an automatic would prove easier, I'd like to see you do it with a stick. The '05-up Mustangs come with a hydraulic clutch release setup, and those Shelbys have a very strong T56. I'd like to see you do that, because if I copied you, I'd be using the TR3650, as I'm not shooting for 9s.
Old Nov 19, 2008 | 05:34 AM
proxemics's Avatar
Car: 87 Z28
Engine: 383
Transmission: th350
Re: 351w swap
I'll update you on this as soon as I get the engine
Old Nov 19, 2008 | 05:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 351w swap
blaspheme!!!!!!
aside from that, if the motor does run 9's, in the 1/4? im sure its not a streetable motor, i dont know what you do with the car, but if its not a full on drag car i would pass.
Also, i believe ford motors have the oil pan sump in the front, i dont know how you would make that fit with the k-member without a TON of fab work.
Old Nov 19, 2008 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by //<86TA>\\
blaspheme!!!!!!
i dont know what you do with the car...
Perfect for PINKS.
Old Nov 22, 2008 | 05:37 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 351w swap
to '86 T/A, yes, most fords were front sump, but the 5.0 mustangs were sort of rear sump, and with a tubular k-member, it'd be easy. Ford Racing themselves, as well as Moroso and Milodon offer pans to put the 351W in the 5.0 mustangs.
Old Nov 23, 2008 | 01:16 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: 351w swap
probably wouldnt be too hard to fab up an oil pan. Its just a box with one side missing, and holes drilled in on the lip. Gonna have a tough time with the oil pickup though...
Old Nov 23, 2008 | 06:49 PM
imjustsean's Avatar
Car: 91 rs
Engine: 305 tbi
Re: 351w swap
i say go for it! i'm not by any stretch of the imagination a ford fan but if you've got a B/A ford motor and want a fast camaro go for it. i've heard rumors of a 351 in tulsa running 10s in the 1/4 sounds pretty cool i cant wait to see the finished product!
Old Nov 24, 2008 | 11:46 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 351w swap
A good reason to use existing pans and pickups, and play with the K-member instead. Unlike playing with the pan, playing with the K-member gives a chance to shave 10-40 pounds.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
