Engine swap questions
Old Jan 21, 2009 | 10:58 AM
Blk91Firebird's Avatar
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
This is my first post and I have a 91' Firebird with a 3.1 and am thinking about swapping it for a 77' stock 350 what kind of issues will I have with trying to do this swap? I have read the V6 to V8 Swap - READ BEFORE POSTING NEW! but it doesn't say anything about using an older motor just that you should get one from the same year or newer... and I'm much better equipped to work on carbureted engines since I understand nothing about MPFI...
Old Jan 21, 2009 | 05:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
First understand that no carb'd engine is emissions legal in any of the 50 United States in a '91 f-body. Doesn't matter where you live, whether they inspect or test, it isn't legal to drive it on public streets, roads, or by-ways.
Having said that, the intent of the statement in the sticky about same year or newer had to do with ease of parts transfer from donor car to receptor car. That doesn't mean you can't physically put an older engine in and get it to run.
How old of an engine are you talking about?
Old Jan 21, 2009 | 07:03 PM
Re: Engine swap questions
1977 Chevrolet 350 dont know yet if Its a 4 bolt main or not need do a basic rebuild on it... Switched from carbureted after 87' didnt they?
Old Jan 21, 2009 | 09:34 PM
five7kid's Avatar
Carburetors came on some things through 1988. f-bodies got them through '87.
Not that it makes a lot of difference what came on it. You can build it with most anything.
Old Jan 22, 2009 | 04:48 PM
okay
Old Jan 28, 2009 | 03:48 PM
Checked with local inspection and they said that it was illegal but that they didn't check underneath the hood on any inspection the biggest thing that they care about now is that I have mufflers and a catalytic converter, but what kind of issues will I have doing this swap?
Old Jan 28, 2009 | 06:07 PM
five7kid's Avatar
The primary issues you'll have involve the 3rd gen specific parts you'll need that won't be on a '77 engine. Pretty much documented in the sticky.
Old Feb 3, 2009 | 04:20 AM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
FYI, I contemplated the same swap and found to make it work I needed headers (to clear dip stick on DR side) After pricing headers, Y pipe, and aggravation factors of emissions, I could purchase a later model 350 cheaper and reuse a lot off old motor. A V6 does not have parts to swap, but they can be found in junk yards reasonably priced.
Old Feb 3, 2009 | 02:24 PM
Already started on rebuilding the engine so it would be kinda pointless to get a newer 350 now but I do really appreciate that information should probably start looking for headers...
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
