Stroker oil pan
Old Jan 25, 2009 | 12:44 PM
snowstorm's Avatar
Car: -86 camaro Z28
Engine: 383 w/HSR com950
Transmission: 700R4 raptor, level III
Axle/Gears: Strange 12-Bolt, 3.42
Stroker oil pan
Hi guys, wondering if you could help me choose oil pan for my -72 350 engine. The car is a -86 camaro Z28. I’m stroking it to 383, using 3.75” stroke. What oil pan do you recommend using (thinking about clearance to headers and ground)? I want to have as much ground clearance as possible. I have relocated oil filter and are using LT Headmann but considering hooker 2055 headers.
Appreciate feedback
Old Jan 25, 2009 | 12:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Stroker oil pan
Any early SBC pan will work. Even if you use a deep sump pan, there won't be a ground clearance issue.
Old Jan 27, 2009 | 09:23 AM
snowstorm's Avatar
Car: -86 camaro Z28
Re: Stroker oil pan
Thanks Stephen. Just wanted to be shore I don’t by an oil pan witch would interfere with the headers/K-member and not be a ground-clearance issue if I lower the car 1 or 2 inches.
Old Aug 13, 2009 | 09:45 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
Re: Stroker oil pan
Exactly what I wanted to know also, thanks Stephen!
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
