'87 305 TPI swap to 350 TPI
Old Apr 22, 2009 | 07:18 PM
87SnowFlake's Avatar
Car: 87 IROC-Z
Engine: jasper 350
Transmission: 700R-4
Axle/Gears: 2.73 posi
I know there are a lot of swap threads but, i haven't found a straight answer. I have a '87 IROC with a 305 LB9 but it has a rod knock so i need a new motor. I want to put a 350 in there but what do i need to replace? Do i need to reprogram my computer? If possible i would prefer a 350 vortec but i'm not sure how much work that will be and if its worth it.
Old Apr 23, 2009 | 07:18 PM
Car: 87 IROC-Z
Engine: jasper 350
Re: '87 305 TPI swap to 350 TPI
anyone? well i was talking with howell auto and they said that for the computer i need to get a prom for a 350?
Old Apr 23, 2009 | 11:06 PM
Awesome-X's Avatar
Car: 87 Camaro
You'll need to burn the prom for the 350 settings or just get the 350 computer altogether, the block obviously, and you'll need larger injectors. I think thats about it.
Old Apr 24, 2009 | 03:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'87 is MAF, which is pretty forgiving to displacement changes. You can always expect to get better performance out of the car with PROM tuning, but it isn't a must-have.
Knock sensor and module should be changed to 350 parts.
Injectors are optional. 22 lb 350 injectors give you WOT margin, but 19 lb will usually do the job.
Old Apr 25, 2009 | 06:53 PM
Car: 87 IROC-Z
Engine: jasper 350
what is the better of the low cost GM crate engines?
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
