4 bolt main
Old Jun 28, 2009 | 09:55 PM
wesrams1's Avatar
Car: 1992 Camaro RS
Engine: 350 .060 over
Transmission: stock
Axle/Gears: stock for now
4 bolt main
Would the 305 in my 1992 camaro RS be a 4 bolt main? How can you tell?
Old Jun 28, 2009 | 10:17 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: 4 bolt main
No. The one from my 91 RS was 2 bolt. I am fairly certain that all 305 blocks have always been 2 bolt.
Old Jun 29, 2009 | 12:11 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: 4 bolt main
AFAIK there were never any 4-bolt main 305's built, but any SBC can be converted to 4-bolt mains.
Old Jun 29, 2009 | 12:36 AM
wesrams1's Avatar
Car: 1992 Camaro RS
Transmission: stock
Re: 4 bolt main
so if im dropping in a 350 would i have to drop in a 2 bolt main engine? or could i drop in a 4 bolt main in?
Old Jun 29, 2009 | 01:16 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Re: 4 bolt main
The amount of bolts on the main caps doesn't matter when it comes to engine swaps. A 2 bolt and 4 bolt block could not be differentiated from unless the oil pan was off or they ran the numbers, and even some casting numbers cover both 2 and 4. 2 or 4 bolt main refers to the quantity of bolts that hold each main cap to the block. There is a benefit of 4 bolt main at higher power outputs but for the average engine 2 bolts works fine.
As someone else mentioned you can convert a 2 bolt block to a 4 bolt if need be and I believe they have more strength because the outer bolts are installed at an angle.
Long story short, don't let the quantity of main cap bolts deter you from an engine swap.
Old Jun 29, 2009 | 01:28 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: 4 bolt main
No they aren't, unless an aftermarket block or main caps are used, and aftermarket main caps with the angled outer bolts can't be used on stock 4-bolt main blocks.
Old Jun 29, 2009 | 01:41 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Re: 4 bolt main
Thats what I was talking about by referencing your original post.
Old Jun 29, 2009 | 01:50 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: 4 bolt main
I just re-read your post and realized that I initially misunderstood the second paragraph.
Old Jun 29, 2009 | 12:00 PM
wesrams1's Avatar
Car: 1992 Camaro RS
Transmission: stock
Re: 4 bolt main
alright thanks alot guys, youve all helped alot
Old Jun 29, 2009 | 02:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Some were made for use in vans. Pretty rare, though.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
fasteddi
Sep 10, 2015 09:32 AM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
