400 Oil Pan
Old Jul 13, 2009 | 06:11 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Transmission: 700 R4
400 Oil Pan
What oil pan is everyone running when they swap a 400. I need a two piece rear main seal and the dipstick is on the other side of the factory motor. Also I have heard you need to run aftermarket headers for the dipstick to fit but I was wondering if stock manifolds and dipstick would work?
Mike
Old Jul 14, 2009 | 08:56 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 400 Oil Pan
The first question has to be why you would consider a 400 but not headers? Those manifolds are a restriction even on a 305, and you're adding 33% more displacement. If you're not going to get headers, there's no sense in the 400. The oilpan for any mid-70s camaro will work fine.
Old Jul 14, 2009 | 04:29 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Re: 400 Oil Pan
Is anyone running deep pans since I have one laying around. The pan is a 7 quart with a small kick out. Also I have heard early V8 thirdgens would work?
The reason I am using stock headers now is because I decided to go aluminum heads. I can upgrade to headers alot more easier than upgrading heads.
Thanks,
Mike
Old Jul 14, 2009 | 04:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 400 Oil Pan
if its two piece main and dipstick is on drivers side then you have alot of pan choices to pick from. Should beable to use any pan designed to fit an fbody with dipstick on driver side with 2pc rear main
two piece blocks with dipstick on passenger side are from 80-85 and there is less of an option there but i'm not sure where the location is on 400's.
Old Jul 15, 2009 | 01:48 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
Re: 400 Oil Pan
Really? i thought passenger side dipsticks were in earlier years than that, the 350 I'm building now came out of a '77 silverado and has passenger side dipstick.
Old Jul 15, 2009 | 06:38 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 400 Oil Pan
really? i just remember when i ordered my oil pan it specified for 2-pc 80-85 small blocks with right hand dipstick
Old Jul 15, 2009 | 10:27 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 400 Oil Pan
'77 was driver side dipstick, thus that 350 isn't the original for that truck.
Old Jul 16, 2009 | 01:36 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
Re: 400 Oil Pan
Well I guess not then, learn something new everyday.
Old Jul 22, 2009 | 05:27 PM
Tallpaul's Avatar
Re: 400 Oil Pan
Then a pan from a 70 -79 Camaro would work? Clearance for the crossmember and exhaust would not be a problem?
Old Jul 24, 2009 | 01:25 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Re: 400 Oil Pan
Bump, Anyone??
Hotrodboba400
Dec 10, 2019 07:07 PM
BDR
Nov 7, 2015 03:05 PM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
