CAN I KEEP MY 5 SPEED IF..
Old Aug 16, 2009 | 10:05 AM
cody88formula's Avatar
I have a 305 in my 88 wit a 5 speed trans. If i put a 350 in it will i b able to keep the 5 speed?? reason i ask is i know they never came factory with the 5.7 and 5 speed
Old Aug 16, 2009 | 10:08 AM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
Re: CAN I KEEP MY 5 SPEED IF..
Yes. My car is exactly that.
Old Aug 16, 2009 | 04:01 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Yep, I'm running that setup in my 91 with no problems so far.
Old Aug 16, 2009 | 04:57 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I have read stories from both sides on this issue. From what I understand you need to ease in and out of gears before you pour on the torque. Once in gear you can feed the power on. Go slow in/out or you will fry the clutch.
Old Aug 17, 2009 | 10:40 AM
doglogan's Avatar
Car: 84 Camaro
Engine: 4bbl 350
Transmission: 5 speed manual
I also have put a 350 in a 5 speed car. What clutches do you guys use? I have a Zoom in mine and after 4000 miles it's toast.
Old Aug 17, 2009 | 10:53 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Yep, i have ad well over 400 HP in front of a 5 speed(world class) and it took a long time to break it.
Old Aug 17, 2009 | 11:51 AM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Yes, you can use your 5 speed with the 5.7L. My old engine was a 305 cid and swap to a 350cid 300hp Goodwrench engine. Works fine.
Hope this helps.
Old Aug 20, 2009 | 07:12 PM
88 Iroc Project's Avatar
Car: 88 Iroc TT
Engine: Gen 2 LT1 Carbed
Transmission: WC T5
Axle/Gears: 10 Bolt
Are you all using the "world class" T5?
I'm about to do this to my 88 but it has the the standard T5(i think) which I'm told is a real weak tranny?
Just picked up 95 LT1 350 out of a police cruiser. Rebuilt with comp cam (Xtreme Energy 276HR-14), worked vortec heads, etc... I'm thinkin I'll probably smoke the T5 in a week On a low budget so thought I would rebuild the T5 while the motor was out but is it worth the effort??
Old Aug 21, 2009 | 01:10 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
T-56 imho
Old Aug 21, 2009 | 07:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you drive reasonably, the T5, even a non-WC, should last a good long while--at least mine has.
JamesC
Old Aug 21, 2009 | 08:16 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I have a V6 WC T5 behind my 350. It seems to be holding up ok. Sometimes is won't downshift from 5th to 4th, but I'm sure its due to some problems I ran into while rebuilding the transmission, not to any problems with being behind a 350. I haven't run it full out yet due to some tuning issues with my carb, but 1/2-3/4 throttle pulls haven't hurt it yet.
As for clutch disc, I had to use a slightly smaller one due to the V6's input shaft, but its a regular Autozone OEM replacement disc. It does slip a bit sometimes when I get on the throttle hard from a roll.
Old Aug 21, 2009 | 01:32 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Good luck making GEN I heads work on a GEN II motor.
Old Aug 21, 2009 | 01:47 PM
Car: 88 Iroc TT
Transmission: WC T5
Axle/Gears: 10 Bolt
Originally Posted by ZONES89RS
God luck making GEN I heads work on a GEN II motor.
LOL my bad they are the correct LT1 "cast iron"heads (gen 2) ;just read somewhere that they are almost identical so I called them Vortec DUH!!.
LOL
Old Aug 24, 2009 | 05:47 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I had no idea the V6 T5 would even bolt up. A 3rd or 4th gen V6 T5?
Old Aug 24, 2009 | 10:14 PM
Chevy8588's Avatar
if you change the bellhouseing on the T-5 to that of the V8 its a direct fit
Old Aug 26, 2009 | 09:01 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Its a 3rdgen V6 T5. Its the one that was in the car when I got it. I had to change the bellhousing, clutch fork, flywheel and pressure plate to the ones from a V8. You can either buy a specially made clutch disc from Summit made by Centerforce or you can use one from an early 80's AstroVan. The AstroVan one is slightly smaller at something like 9 15/16 but it works. It slips a bit when I get on it, but that's probably due to the fact that I put in a used pressure plate.
Old Aug 27, 2009 | 10:33 PM
1qk4mula's Avatar
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
U also have to cut the input shaft on v6 t5. to make it work.
And I had problems finding a clutch that works cause of the different splines. I dont think center forse makes that disk anymore.
Old Aug 27, 2009 | 10:36 PM
1qk4mula's Avatar
I have 88 non wc t5 behind my 350 tpi. (300 hp) beat on it all the time never had a problem. Mind u my tires don't stick at all... And i blip the throttle when i down shift
Old Aug 28, 2009 | 07:50 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
You're right about the input shaft. I don't know how I forgot about that since I cracked my bellhousing because of it. I was stupid and tried to use the bellhousing bolts to pull it against the engine instead of checking to see why it didn't want to fit. I cut about 1/4" off of mine and then spun it while holding an angle grinder against the nose of the input shaft to put the taper back on it.
The clutch I used is for an 82 GMC S15 with the 2.8L V6. Part number at Autozone is CP4201. Its 9 11/16" diameter and the list price is 25.99 w/ a core of 6.
I just checked Summit and you're right, they apparently don't make that conversion clutch disc anymore. The closest ones I found are 9.75" and 11". I can't remember if an 11" clutch disc will fit or not. You'll need one that fits a 14-spline 1" input shaft.
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
RedLeader289
Sep 23, 2015 06:50 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
