Question on 91 RS V6 to carb 350.......
Old Oct 19, 2000 | 10:20 AM
UDO1NUN's Avatar
I am planning on swapping out the V6 for a carbed 350. I will be swapping out the T5 for a T56 from a late camaro/transam. My questions are in what distributor to use?
I have a 89 block, is there a special distributor for the roller cams gear? I plan to use MSD and a 6al. My motor plans are as follows:
350 long rod
AFR 195's or Trick Flow 23*
Performer RPM
3310-1 780 cfm vac. holley (old school)
I am unsure on the cam, I would like to have the heads flowed and one custom grinded, who is the cam man around here?
Old Oct 19, 2000 | 12:31 PM
Blade's Avatar
As for the distributor any vacuum advance unit will work. Just make sure it has a bronze gear on it for that roller cam.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
sreZ28
Oct 22, 2015 08:21 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
