Anyone go from 305 to 350 Edelbrock 3500 series?
Old Jan 8, 2001 | 11:39 PM
Mike92's Avatar
If so what are the main obstacles, where did you get the fuel lines, how much and did they go in the stock location? Also, what's your combo, edelbrock say's with fully ported S/R torquers 2.02/1.6 and a 9.7 Comp with Hot cam I couldn't make 400HP, how close would I be at least 360HP, right?
Old Jan 8, 2001 | 11:44 PM
Mike92's Avatar
It's a 305 TBI , now.
Old Jan 9, 2001 | 08:09 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
Are you talking about the Edelbrock ProFlo #3500 fuel injection?
Old Jan 10, 2001 | 08:36 PM
Mike92's Avatar
Yeah, the performer RPM Pro Flo EFI #3500 Stand alone kit for $1925.00. Anyone do this or a similar swap and have to change out the fuel lines to larger ones?
Old Jan 16, 2001 | 10:20 AM
Mike92's Avatar
BTT?!
Old Jan 18, 2001 | 02:09 PM
Hurtin4Hp's Avatar
Engine: 400 sbc
I did the swap from a V6 to a 400 with the Pro Flo #3500. I used the stock fuel lines in my '86. The supply line is 3/8" and the return line is 5/16" which is what Edelbrock recommends. I put a pressure gauge on it and it holds fine under load. You can email me if you have other questions.
Old Jan 18, 2001 | 06:50 PM
Mike92's Avatar
What are the specs on your engine, I think a 400 would kick *** on torque production. Does it overheat or anything? Also how easy was the tuning, Do you get alot of lowend with that single plane manifold and Have you run it at the track yet? And If that ain't enought questions then how about what's your cam, head, and Compression Ratio? Thanks
Old Jan 22, 2001 | 07:40 PM
Hurtin4Hp's Avatar
Engine: 400 sbc
Obviously traction is a major problem. The 235's on the rear won't grab at all in first without really feathering the throttle and if I shift to second at more than half throttle the tires break again(700R4 with a PowerTrax No-Slip locker). Adjusting the idle setup is probably the most difficult. I'm still playing with it. The temperature has been fine this winter but the true test will be this summer(I finished the install in November). I did install a Griffin HP series aluminum radiator that has two 1-1/4" rows, and I reused my single electric fan from the V6. The compression ratio is 10.71:1. I hope to take the car to a chassis dyno to do some final tuning some time in February, and then I will get some times at the track.
Sig test:
400 Small Block Engine Mods:
  • Scat 9000 Series Internally Balanced Crank
  • Scat 4130 I beam 6" bushed rods
  • JE flat tops .040" over
  • SpeedPro File Fit rings
  • Moroso 7qt oil pan
  • Crane PowerMax 278 cam (222/234 @ .050; .498/.526 w/ 1.6 rockers)
  • Crane PowerMax hyd lifters
  • Crane Energizer 1.6 Roller Rockers
  • Edelbrock Performer RPM 70cc Aluminum Heads
  • Stud girdles
  • Moroso tall valve covers
  • Edelbrock ProFlo FI
  • Hooker Long Tube Headers
  • Edelbrock Victor Series Water Pump
  • K&N 4" Air Filter Assembly
  • ARP bolts/studs
  • etc, etc.
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
fasteddi
Sep 2, 2015 10:29 AM
st.evel07
Aug 13, 2015 06:15 PM
