what performance parts to use on a TPI 383?
Old Apr 26, 2001 | 09:22 AM
Cruising270's Avatar
I'm looking to get a 383 built this summer. I'm going to start ordering parts piece by piece, and I want to hear your ideas on what to get. Here is the rules, it will retain the TPI not carb, so the heads must bolt to this style intake. Also I want to keep it on a slight budget, I want the best HP for the money. So what cam, TPI upgrades, heads, etc would you recomend. Thanks for your input.
Old Apr 26, 2001 | 12:00 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm currently building my 383 on a college student budget, so here's what I have. 190 AFR heads, Edelbrock lower intake, Super Ram plenum and runners, 24lb/hr SVO injectors. To save some money you can go with some other aftermarket runners and port your stock plenum or port the plenum and runners. You can also save some money by getting something like Trickflow heads instead of the AFR's, but why not get the best when heads are what compliments the combination most? Hope this helps.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old Apr 26, 2001 | 01:26 PM
Ohh thanks for the info man and ideas man. Just curious man but how much are you looking to spend? Also did you get a short block 383?
Old Apr 26, 2001 | 05:25 PM
Car: 89 IROC-Z
Engine: 383
I did not get a short block.....I got all of my parts seperately. The engine is going to cost me upwards of $4k....maybe a little more.
Old Apr 26, 2001 | 09:30 PM
I see man, thats cool. Well good luck with it all.
Old Apr 27, 2001 | 07:11 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Paul, You are on a college budget? Man i wish i was on the same buget as you are! And i even goto school part time!
Don't skimp on the heads. Especially with a 383. If you don't want Al (remember to bump the CR 1 point if you do use Al) the Sportsman II's are a good head.
Here are a few sites that have some nice 383 engines:
http://www.enginefactory.com/
http://www.speedomotive.com/
You will probably want to dich the original TPI intake in the end. An aftermarket intake base is a must. I would recomend the ASM (can't quite remember the name) runners. I have heard they are the best but a little pricey. You can always upgrade the runners later, but i would start with the base first.
[This message has been edited by Omega (edited April 27, 2001).]
Old Apr 27, 2001 | 10:54 AM
Car: 89 IROC-Z
Engine: 383
Omega.....let's just say that when I got my car at age 16 I knew immediately what I wanted to do with it and since then I've been living like a miser to save all my pennies. With the money I've got in the bank and the money I'll make this summer I should have enough to complete the project. Then I just have to start saving for my 69 Camaro next.
--RPM Racing--
Old Apr 27, 2001 | 09:06 PM
Thanks for the links and advice. I was looking into going for the SLP runners. The plenum will have to stay stock, I can't afford nicer one. I was thinking about some Vortec heads because of their budget cost. I want a half decent cam too, but nothing to fancy, I don't want to increase the reving much higher because of the poor flow of the TPI. I'd like to here from more people who accully run a 383 TPI, to see what they did.
Old Apr 27, 2001 | 09:54 PM
camaroguy99's Avatar
unless I'm mistaken they still haven't completed the TPI intake manifold for the vortec heads. A stock or aftermarket replacement won't work with vortec heads
Old Apr 28, 2001 | 08:40 PM
Oh really, damn I see. Well who makes some bang for the buck TPI Iron or alum heads.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
86IROC112
Aug 17, 2015 02:00 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
