Serpentine Accessories in an 86?
Old Jun 12, 2001 | 12:33 PM
86Z28TPI's Avatar
Can I strip the accessories off of an 88 305 and replace my 4 V-belt setup on my 86? Does anyone have a pic they can email me of the stock serpentine system for 88-92?? Any help would be greatly aprreciated. Thanks!
'86 IROC Z28 TPI 305. Modified air box, K&N filters, Air Foil, SLP headers and exhaust sytem, Comp Cams 1.52 Magnum roller tip rockers and springs, lightweight valves, Accel Super Coil and wires, Adjustable FPR, and tons of elbow grease!
Old Jun 12, 2001 | 01:53 PM
MAXGTA2002's Avatar
The first thing you need to check for is the a/c unit, what side is it on, you might have to change the position of it and the water pump are diferent the 88 don't have all the holes the 86 has and i beleive there will be a clearence problem, and I beleive the bolt hole on the heads were diferent on my l98 these were the problems I run into, changing them out, hope this will help
Old Jun 12, 2001 | 02:08 PM
86Z28TPI's Avatar
Thanks. Yeah my A/C is on the drivers side. I have to swap that with the alternator. I was planning on new pulley for smog and steering, and new alt and comp. I am also getting a Sanden A/C compressor from vintageair.com and going to 134a. All those V-belts are ugly!!!! I hope this works! Any other ideas?
Old Jun 12, 2001 | 08:32 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The alternators are different too (i think).
The newer serpentine's are the smaller cs alternators instead of the 10si full sizes. There's also two different front plate bolt patterns on these alternators, one for the 60 degree v6's and one from the v8's and 4.3's.
I though it was in the clocking, but after checking it further... they're different. I scored a complete setup out of a 4.3 blazer at the junkyard with the power steering pump, alternator, reverse rotation water pump (don't forget this big difference, as overheats will set in afterwards) and crank pulley... The whole deal with the tensioner and smog pump (which I removed..)
I could of taken the compressor. It might be easier just to switch everything instead of piecing it together, of course you lose the refrigerant doing this, but there's only two o-rings there that should be changed anyway...
Old Jun 16, 2001 | 05:45 PM
86Z28TPI's Avatar
Thanks. Any other idea or considerations?
Old Jun 24, 2001 | 09:22 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you want to swap, you need to read this: Serp belt swap
As for using a trucks, it won't work. The trucks passenger side bracket has the A/C compressor to high and it will hit the hood. The F-bodys bracket moves the compressor closer to the fender allowing it to sit lower.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
jrdturbo
Mar 31, 2016 02:58 PM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
355tpipickup
Sep 28, 2015 05:50 PM
evilstuie
Sep 24, 2015 02:31 AM
