305 to 2.8
Old Jun 25, 2001 | 04:10 PM
84Berlinetta305's Avatar
305 to 2.8
My 305 is currently on it's last leg, and I have a perfectly fine 2.8 with everything in my parts car. So instead of buying a 350, I am going to put the 2.8 in. How much am I going to need from the part car in terms of the computer and the harness? I know how to change a motor of the same number of pistons, but what differences will there be in this change? Thanks alot for the help.
Oh yeah, I know half of you are going to tell me to get a 350, but I don't want one, because I already have the 2.8 with tranny and all, and that is some serious $ I don't have to spend
Old Jun 25, 2001 | 05:01 PM
Tas's Avatar
Tas
sell that 2.8 to someone that has blown theirs(I know there must be plenty) and put in a basic GM Goodwrench 350. That way you have tons of reusable parts and no messing with rewiring your car.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited June 25, 2001).]
Old Jun 25, 2001 | 08:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd have to echo that recommendation. Having gone the other way, I know it is a lot of work, and wouldn't be any less work going the direction you suggest. The benefits would be much less to boot.
You'd be better off driving your parts car.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 25, 2001 | 09:17 PM
Well, I wish I could drive my part car, becaue that was my first camaro. Then my sister wrecked it, so it is kinda outta commission, unless I wanna get a new body, frame, etc! But, the thing is, I have a 2.8, and I don't wanna go through the trouble of selling it and getting a 350. I am just 17, and am only making 7 an hour, so money is a big deal, and I'd like to make do with what I have.
Old Jun 26, 2001 | 09:23 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
The other guys have offered the best advice. You will spend LOTS of time. You will need to swap engine wiring harness and computer then swap engine and transmission from donor car to decrease the value of your car $1000. Gm made alot of 2.8L vehicles. Your 2.8L with trans would be worth a good $500 to $600 bucks if it runs ok. That will buy you a 350 shortblock anyway. Long block would be MUCH better but you say your on a tight budget.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
Old Jun 26, 2001 | 11:31 AM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Just wondering but, I'm not sure if Berlinetas cam with tachs but if it did you would have to replace it with a V6 type. The guys are right about getting a V8, and I presently have a Camaro 2.8 which I'm swapping to a 3.4. Your going to be disapointed in the lack of power the 2.8 puts out.
You can sell your parts and find an engine at places like :
http://www.tacreationsusa.com/v8.htm
or
http://www.junkyarddog.com/main.htm
Old Jun 26, 2001 | 10:41 PM
Ok, you guys have talked me into getting a new v-8. Now the question is, which one? I picked up a local classifie paper, and found several for sale within my budget. Which of the following will go the smoothest with my current 84 lg4 with a th700r4?
'82 350
'82 305
'88 350
'77 350?
and then there are a couple of just plain 350's one of which is complete, and has 4 bolt mains. I know that this is better, but what makes 4 bolt's better?
Thanks alot guys.
Old Jun 26, 2001 | 10:45 PM
Tas's Avatar
Tas
also check www.sdpc2000.com they have real GM replacement engines which are the cheapest.
Old Jun 27, 2001 | 04:00 AM
Jza's Avatar
Jza
Easiest would be an 86 or older engine so you don't have to deal with bolt holes not lining up on some of your accessories.
Old Jun 27, 2001 | 07:44 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Another option is to go to your nearest 'hole in the wall' auto machine shop and tell them your woes. Maybe rebuildin' the 305 or they may have a 350 around will cost less than you think (If they're slow)
Old Jun 27, 2001 | 01:23 PM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jza:
Easiest would be an 86 or older engine so you don't have to deal with bolt holes not lining up on some of your accessories.</font>
Except no older than '79 (I think) - driver's side dipstick.
Old Jun 27, 2001 | 01:53 PM
What difference does a drivers side dipstick make?
Old Jun 28, 2001 | 02:51 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
the difference between drivers and passenger side dipstick is the driver-side dipstick doesn't fit well around the exhaust manifold. if you ran headers, it might work ok, im guessing.
Old Jun 28, 2001 | 03:07 PM
five7kid's Avatar
And oil pan.
Old Jun 28, 2001 | 03:25 PM
Tas's Avatar
Tas
[This message has been edited by Tas (edited June 28, 2001).]
Old Jun 29, 2001 | 08:55 AM
ImportsRsloths's Avatar
Man,
You should go take the intake manifold off of that car and pour some sand in there.... then start that bad boy up! In about a week go out there to try and start that piece of **** and it will run horribly (if it does) and then show your mom... time for 350 if you ask me
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
GouldyGTR
Sep 7, 2015 09:05 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
