Oil Pan Selection
Car: 1984 TA 15th Anniv. Addition
Engine: 355 SBC
Transmission: TH350
Axle/Gears: 4.56
Oil Pan Selection
I did a search but came up with no results.
Is there a thread on what oil pans work on the 3rd gens?
Specific Application: 1984 T/A with a 383 SBC
Hooker Super Comp Headers (1 3/4)
Stock K Member
Stock Ride Height
Is a deeper stock style pan my only option?
Thanks.
Stock K Member
Stock Ride Height
Thanks.
Transmission: 4L80E/4L80E
The "regular" pans work fine. You need to match the pan to your dip stick location and rear main seal type.
Deep pans reduce ground clearance. Kick-out pans get in the way of exhaust routing.
A 4-quart pan, good high pressure regular volume oil pump, and synthetic oil ("real" PAO synthetic, not the faux synthetics most companies offer) is all you need.
Engine: 355 SBC
Transmission: TH350
Axle/Gears: 4.56
Re: Oil Pan Selection
Thanks for the reply. I needed the help so I can decide which pan I need / want.
Thanks for the help.
