89 Camaro engine swaps
Old Jan 19, 2010 | 03:18 AM
PAIMON's Avatar
Car: 1989 Camaro RS Convertible
Engine: Need help identifying
what other camaro engines will fit in my 89 Rs
it was orinally a V8 305 TBI
automatic
what other camaro or corvette engines can i get
Old Jan 19, 2010 | 07:14 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: 89 Camaro engine swaps
automatic
Any chevy big block or small block will fit with a little bit of work.
The problem is if you don't go to carbed you are looking at replacing the computer and harness if you go to a bigger motor or a different form of fuel injection.
Old Jan 19, 2010 | 08:26 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
being in California, you're a bit more limited due to the emissions regulations. You've got to go by the book moreso than the rest of us (which unfortunately means no big block zraffz)
They're going to be picky about what they see and what it puts out for exhaust, so you need to make sure anything you swap is CARB-certified
Old Jan 19, 2010 | 12:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'89-later B-body (Caprice, Roadmaster, etc.) are also legal.
Basically, has to be a passenger car engine '89-later, with all of the emissions equipment that came with the car from which the engine comes (or, as stated, CARB-certified replacement parts).
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
