GM 350 L05 Caprice Engines????
Old Aug 28, 2001 | 08:32 PM
CloudIROCZ28's Avatar
This Engine complete is $1487 I'm wondering if This would be a good replacement for my IROC-Z and will my TPI bolt up to it????? and what else would I have to do to make it work??? my original engine is a 305
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. Soon to get new 305 TPI
Old Aug 28, 2001 | 11:23 PM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
yes yes yes respond this is the question we are al waiting for the answer to.
Old Aug 30, 2001 | 12:30 AM
LB87FORMULA's Avatar
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
This is a little long...
I just performed the following engine swap on my 87 Formula, 5 speed because the 305 LB9 TPI, 125K overheated. Swap performed by a trusted auto shop.
Added:
GM #12513151 Caprice 350 - Pace - $1490.40
GM #12551705 LT1 camshaft - Pace - $195.14
SLP #21000 Cold Induction - SLP - $199.95
Transferred from 305:
TPI,intake manifold,PROM,fuel pressure regulator and injectors, belts, pulleys etc.
Problem parts replaced by me:
starter, battery, tempature sensor guage,alarm system
Fixed Problems:
runs poorly - timing set wrong
idle sticks - added new spring
Current Problems:
idle a little rough with surging
(my 305 did the same thing)
Peformance:
Runs great! Much Much stronger than 305.
Significantly stronger 1000-3500rpm
A little lame above 4000rpm. No flat spots.
Computer& Emissions:
No codes.
Will test for Ohio next week.
Recomendations:
How an auto shop can swap a motor but not
set the timing correctly? 14 deg off?
**I would do the motor swap myself.**
I have two cars. My 95 GMC Jimmy, is great in the snow, good for people i.e 4 doors, mush ride and leather, but I drive my Firebird every day to work. Nothing beats a V8, 5speed and handling.
**I would recommend this engine**
Future changes:
New Heads? I've heard nothing but bad things
about these heads. Can they really be that
bad? Right now I need new Tires.
Old Aug 30, 2001 | 07:22 AM
RED92's Avatar
LB87-
I guess you kept your T-5 in? You think it will hold up? What would you guess the horsepower and torque on that motor is since you've had a chance to run it. I have heard horsepower #'s from 210-280 out of the crate depending on who I talked to.
Alex
Old Aug 30, 2001 | 08:29 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Stock L05 put out 210hp. So the LT1 cam should put it near the 240hp range since L05 have the peanut cam. Exhaust put you to 260hp which isn't bad for a new $1500 engine not a rebuilt one with ??? reliability.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
[This message has been edited by brharris27370 (edited September 06, 2001).]
93ND500's Avatar
The heads are the only real drawback with that caprice 350. Well, the cam isn't the greatest either. Been there, done that. If your happy with the perfomance as-is, wait untill you swap the heads out
Old Aug 30, 2001 | 11:39 AM
If you are going to change the heads and cam then the GM L98 350 shortblock would be better. http://www.sdpc2000.com/cart.asp?act...id=514&pid=620
$1135 for a NEW gm 350 shortblock would be great to plant some good heads and cam on.
Brian
Old Sep 3, 2001 | 10:21 AM
nebulous's Avatar
So did LB97FORMULA pass emissions? And are there any engine sellers that will install parts in the engine before they ship it? I know people like recon will, but all I hear from you guys are horror stories about remans.
Old Sep 3, 2001 | 03:35 PM
RED92's Avatar
I am going to make somebody's day here. You probably haven't seen this....
Check this out:
http://www.sdpc2000.com/cart.asp?act...d=689&pid=1061
SD has L05 crate motors with mods! I just ordered the one with the aluminum Edelbrock heads last week. I also had them swap to a different cam. Unfortunately, some of the parts they use are backordered so I don't know when I'll get it.
Alex
Old Sep 5, 2001 | 10:57 AM
nebulous's Avatar
Thats the LO5 Short block? I looked at it, but since it didnt have any good data on the page, I just thought it was a ripoff.
Old Sep 5, 2001 | 02:03 PM
ws6formula89's Avatar
<font face="Verdana, Arial" size="2">Originally posted by brharris27370:
Stock LT5 put out 210hp.</font>
Good *** , I hope those LT5 motors were putting out a lot more than 210 horsepower!
Weren't those the DOHC 32V Corvette motors that were putting out 405 horsepower? Hehe, don't think I'm stupid or anything, I'm just messin with you.
I realize it was a typo.....I hope.
-ws6formula-
Old Sep 6, 2001 | 03:00 PM
O T whats the difference
Old Sep 6, 2001 | 04:51 PM
nebulous's Avatar
The tech at SD told me the LO5 would put out 185hp. I'm hoping thats with carb or TBI. If its that low with TPI its worthless.
Old Sep 6, 2001 | 07:39 PM
Tas's Avatar
Tas
the truck TBI version of the LO5 was 210HP I believe.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 6, 2001 | 09:53 PM
RED92
The 5 speed works great. I put in a new clutch this past winter. The new engine is night and day stronger than the 305. Consequently, I have a serious traction problem, which may lead to an upgrade of some drivetrain components.
This leads to the question everybody wants to know. How much horsepower does the L05 make? Its definitely stronger than the orginal LB9, L98 etc. My next purchase will be G-TECH performance meter. This way I can check some performance figures without going to the track. My emissions test will be some time the next couple days. Hope it passes.
P.S. Jim Pace warehouse told me the engine should make about 275 horsepower with the TPI induction. Thats probably just as crediable as the 185 from SDPC.
Old Sep 6, 2001 | 11:10 PM
RED92's Avatar
The engine I ordered in the link above, will put out in the 275 hp range according to SDPC, I had them swap in a hotter cam and add G.M 1.6 roller rockers. I am expecting about 300hp net. I would guess the stock L05 is good for 230hp, which is what it was rated in the 91-93 Caprice it came in. Truck output was rated lower at 210hp.
Alex
Old Sep 10, 2001 | 07:53 PM
RED92 - Alex
This engine from SDPC sounds great. It wasn't posted when I first checked this site. From the specs posted, I think this should be the best crate engine replacement for 5.0.
My L05 passed Ohio Emissions with the LT1 cam. I am sure the similar SDPC engines will pass.
Good Luck!
xkingcodex
Feb 12, 2020 07:43 PM
Infested
May 22, 2018 11:56 PM
camaro71633
Sep 1, 2015 10:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
