A little advice/help needed. 92 GMC 4.3 to 5.7 swap.
Old Sep 14, 2001 | 08:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I found a sweet 92 GMC 1500 pu. The body/interrior are in excellent condition.
It is a 5 speed 4x4 and they want 1500$ for it. It has a 4.3 in it and its blown. So the only logical way to go for a full size PU is a 350. Has anybody done one of these swaps in a late model truck? I did one in a 86 GMC but the FI went by by and lots of things needed to be converted, I heard that the late model trucks were eaiser to convert from 4.3 to 350 and all the wires/lines are the same, I would just need a computer, manifolds and possibly a larger TBI. Ive also heard that the current clutch and componets would bolt right onto a late model 350??
Any help would be apprciated
Not thirgen but I cant pass up this deal.
SSC
Old Sep 14, 2001 | 09:18 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SSC:
</font>
I've talked to people that said the same thing. From what I understand, you'll need to change the computer and prom. The harness is reported to be the same for both. Everything else (other than the obvious, exhaust manifolds, motor mounts, etc..) should bolt right up.
Old Sep 14, 2001 | 11:53 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thanks RS, I am hoping this could be an easy/ cheap job. What about the tbi though? Ive heard that some people are still using the 4.3 one with just pressure boosted. I think it could be used this engine " If I get the truck" wont be built up or anything, just a plain jain driver.
Thanks!
SSC
85 Camaro, 355/400 "drag car" in moth ***** 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 305/350 currently being moth balled.
Current plans: Rebuild 305 with flat tops instead of the dished "cups" for pistons or slightly built 327 with the 58cc heads from the LG4, Upgrade the 2:73 to 3:73 or 3:42 and replace the turbo 350 with 700r4.
"web site under contruction"
Old Sep 17, 2001 | 01:13 PM
Lowaholic's Avatar
Hey, I'm not too sure about the '92s but I've got a '90 C/K 5.7L in my S-10 Blazer. I pretty much ended up using a 4.3L tbi (same as sbc, I think the pass. side injector is different if I remember correctly), and it's running on an ECM out of a '90 4.3L S-10 (#1227747) and the chip for the '90 5.7L. I had to change 3 or 4 wires at the ECM, and it fired right up. It really depends on what ECM you have. If you really want to do this, my advice is to get HELM electrical manuals (NOT haynes) for both trucks and just compare all circuits before the swap. As long as you know exactly what has to be done beforehand, just plop the V8 in, hook it all up & go cruise. Good luck
Old Sep 18, 2001 | 02:00 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I got the truck sat morning and called gm about an hour later. The guy I talked to wasent sure about a few details either. I just know they now charge cores so It would just be im my intrest to rebuild a 350 and pop it in there. After closer inspection I noticed a rod indention in the oil pan on no.3 so the 4.3 is gone.
Low, how about the flywheel is it the same?
Or anythig elese you might have noticed?
Any Info before I get started on this project would be "VERY" apreciated!
Thanks!
SSC
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bschmale66853
Sep 30, 2015 08:11 PM
usafirebird
Sep 29, 2015 11:58 PM
raymondandretti
Sep 27, 2015 06:43 PM
