Swapping 2.8 for 5.0
Old Sep 12, 2001 | 04:55 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Ok, I've checked out all the information on this site about swapping a V8 into a V6 f-body. One thing that I've noticed is that some people say you will need to swap the cat & cat back exhaust when making the switch others make no mention of it.
What I would like to know is if you HAVE to swap out the exhaust system along with the motor/trans? I just put a new exhaust on my car (a little over 1yr ago) and can't afford to do it again.
If the exhaust has to be changed then I guess I'm putting the V6 back in
TIA,
Don
Black 87 2.8l Camaro
http://photos.yahoo.com/bc/z2point8l?d&.flabel=fld1&.src=ph
Aka Z2point8
Old Sep 13, 2001 | 01:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Without a doubt the stock cat for a V6 will be too small for a V8. But, if you have at least a 2" to 2-1/2" cat & catback, they will support a 305 (depends upon how healthy the 305 is).
The way I put it when discussing the V6 to V8 swap parts-needed topic is "exhaust from the heads to the rear bumper". If you replaced your exhaust with stock-size parts, figure on needing to replace them.
FWIW, between Summit & JC Whitney, my exhaust is costing me around $575. That includes 1-5/8" primary headers, 3" y-pipe, 3" cat and catback to 2-1/2" dual tailpipes.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited September 13, 2001).]
Old Sep 13, 2001 | 02:02 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Thanks,
My exhaust system is a Walker free-flow cat with a Carline Free-flow muffler. All the inlets/outlets are 2 1/4". Total cost was about the same (but in CDN$, Installed)
Old Sep 13, 2001 | 06:04 PM
five7kid's Avatar
That will do, but will be restrictive for anything more than LG4-type power.
You'll need a V8 y-pipe, of course.
Old Sep 14, 2001 | 05:55 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
How do I know if the 5.0 I have is infact an LG4? All I Know is that it came from an '83 and that it was an H.O engine.
Old Sep 15, 2001 | 12:41 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
CanadianCamaro,
If you're interested I've got a complete brand new exhaust system in my garage minus the CAT for a V8. Hooker SuperComp shorty headers, 3" Y-pipe, Flowmaster 3" CAT back with 2-chamber muffler and dual polished 3" outlets with ***** cut tips. I bought it before I got the big block and I can't use it any more. I live in south-eastern Washington. It's not cheap but it will save you about $120 if you want a good exhaust system.
Old Sep 15, 2001 | 12:43 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Well, that's an interesting edit... s-l-a-n-t cut tips.
Old Sep 15, 2001 | 08:58 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Thanks QwkTrip, but at this time I don't have the $. Gotta get a second job this 16hrs a week is B.S.
Soon to be 305/5.0
http://photos.yahoo.com/bc/z2point8l...l=fld1&.src=ph
Aka Z2point8
[This message has been edited by CanadianCamaro (edited September 15, 2001).]
Old Sep 15, 2001 | 10:52 PM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CanadianCamaro:
How do I know if the 5.0 I have is infact an LG4? All I Know is that it came from an '83 and that it was an H.O engine.</font>
If truly an HO, then it is an L69. If possible, get the exhaust off of it - it'll be better than your V6 exhaust.
Old Sep 17, 2001 | 12:07 PM
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
I would but the car is long gone The engine has been sitting out of the car for atleast 4 years, did a compression test & everything seems to be ok
Is there a vin # or something on the block that I use to see if it's an LG4 or L69?
[This message has been edited by CanadianCamaro (edited September 17, 2001).]
Old Sep 18, 2001 | 08:15 AM
Big Money Mike's Avatar
My LG4 has "LG4" stamped either on the block or the intake manifold, I dont remember which.
Mike
Old Sep 19, 2001 | 05:49 PM
five7kid's Avatar
An LG4 will have an "H" in the VIN. I forget what the L69 has.
Old Sep 23, 2001 | 12:32 AM
hiker's Avatar
http://www.mortec.com/castnum.htm if you have the id numbers go to this site and it will tell you pretty much everything to do with the motor you have in your hands
Cleotiz
Jan 6, 2018 08:56 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
