drift car........need engine help
Old Feb 6, 2010 | 08:52 PM
the86bluebeast's Avatar
Car: 86 iroc/ 86 K5
Engine: none right now/ gm crate 350
Transmission: t56 on the way/ 700r4
Axle/Gears: 3.08/ 3.42
i am currently deployed and have wanted to build my 86 into a drift car for a while. i would like to use a big block, but i am not sure just which route to go. big bore - short stroke high rpm? or just go with a stroker? anyone that has any expirence in this area would help greatly. (i know.....most people make drag cars out of f bodies, i like to be different)
Old Feb 6, 2010 | 08:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: drift car........need engine help
I know nothing about drifting, but would you really want to make the weight imbalance that much worse?
Old Feb 6, 2010 | 08:59 PM
Car: 86 iroc/ 86 K5
how much more does a big block with alum heads weigh than an all iron small block ?
Old Feb 6, 2010 | 09:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A couple hundred pounds, but the big block is longer so that weight is even farther out.
Old Feb 7, 2010 | 12:12 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
I thought a big block with an aluminum intake and heads weighed about as much as an all iron small block, give or take?
Old Feb 7, 2010 | 01:02 AM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
It does.
Old Feb 7, 2010 | 06:21 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I dunno.. .aluminum heads are worth 50 lbs... and I've heard that the bbc's are about 200 lbs heavier before too.
You'd be better off going LS I think. But I think a stout 350 would do fine for you. As long as it has decent throttle response and a T56 or better bolted to it.
Old Feb 7, 2010 | 06:49 AM
Car: 86 iroc/ 86 K5
i had plans for a t56 to rest behind the motor. all great input, and i really suppose it doesnt HAVE to be a big block. but nobody really answered my question. what would be better? big bore and short stroke? or just get the low end grunt of a stroker motor?
Old Feb 7, 2010 | 03:37 PM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Probably what you ought to do is go post on a drifting board and find out what engine characteristics you want in an engine for a drift car, then once you know that come back here and, knowing if you want midrange, high end or low end ask again and then you'll get some concrete answers.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
