fuel pump problem
Old Feb 13, 2010 | 05:03 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
fuel pump problem
ok, so my name is matt, and i have a 92 camaro z28 with a 305 TPI. i just put in a brand new 350 engine with a carb...took out all emmisions and computer. but im having some problems.
-Because i am not computer controlled anymore, i need a new fuel pump. i did not take out the old one at the tank. i just cut out the factory fuel filter and placed my summit high flow pump there. hooked up to a malloy swich to turn it on, to my dash. NOW when i turn the swich on all i hear is a LOAD winding noise from my pump, but no gas flow. im not sure if i put it in wrong or upside down. please help.
Attached Thumbnails fuel pump problem-p1010201ggggg.jpg   fuel pump problem-p1010203mmmmmm.jpg   fuel pump problem-p1010200iii.jpg
Old Feb 13, 2010 | 06:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel pump problem
That pump's probably not going to like trying to suck fuel through the in-tank pump.
If you didn't want to take out the stock pump, why not just keep it and use a regulator?
Old Feb 13, 2010 | 06:56 PM
defaria27's Avatar
i read that wouldnt be a problem. how do u take out factory pump? i know i have to drop tank. isnt inside the tank?
also i took out my ecu.. so i manualy wired my car...i was told i had to do so...esc, from converting from 305 to 350 carbed
Old Feb 13, 2010 | 09:54 PM
SeanW's Avatar
I have the same pump. Are you sure it isn't plumbed backward?
Old Feb 14, 2010 | 03:34 AM
defaria27's Avatar
does the wire come out the top front or the bottem front? in the pick mine is coming out the top....also did you put yours in the same spot
Old Feb 14, 2010 | 12:34 PM
SeanW's Avatar
Mine is in my 86 1/2 ton, so no not in the same spot. I just went and checked and i think you have it plumbed backwards. My relief valve access plug is on the suction side of my pump. You have yours set up on the pressure side.
Old Feb 14, 2010 | 02:07 PM
defaria27's Avatar
so i can just swith the hosing or do i have to take it off or turn it? for example..on my pic...should the summit sign be facing the front of the car or back, or that doesnt matter...just the hoses?
Old Feb 14, 2010 | 02:50 PM
SeanW's Avatar
Just switching the hosing might be a little sloppy but it will certainly work to double check that it is indeed the problem.
Or you could just turn the pump upside down.
Old Feb 14, 2010 | 03:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You'll kill that pump quick trying to pull fuel through the dead in-tank pump. You really should have used the in-tank pump, and ran a regulator (Mallory 4309) for the carb. You'll have to take that pump out now, or rewire it to run again.
And yes, you have to drop the tank, which means taking out the exhaust, dropping the rear axle as far as you can without breaking/stretching the driver side brake line, removing the tank, and taking the pump out through the top, unless you do the hack and cut an access hole in through the rear trunk.
If it were me, I'd go back, make the in-tank pump work again, and get the correct regulator - much easier than dropping the tank to remove the old pump and make the el-cheapo electric pump you bought work.
Is this car an automatic? If so you'll need geometry correctors for the tranny and a lock-up kit for the torque converter too!
Old Feb 14, 2010 | 05:47 PM
defaria27's Avatar
yea the pump was deff in the wrong way....it pumps gas but its still so god damb noisy, and camaronewbie, if i was going to use the old pump...how the hell do i wire that...also will that one be strong enough hence i am running a carb. and yes i put in the torq lock up kit. but wth is eometry correctors for the tranny....? also rememeber for the factory fuel pump. i do not have my engine bay wire harness anymore..that means no more relay. but i did hook the new one up with a relay kit from summit.
Old Feb 14, 2010 | 05:53 PM
SeanW's Avatar
Yeah they really are noisy pumps. I never understood why some pumps were sold as "quiet running" until i put this one in.
Old Feb 14, 2010 | 05:55 PM
defaria27's Avatar
i mean this on is LOAD...did u also take ur old pump out?
Old Feb 14, 2010 | 06:00 PM
SeanW's Avatar
When i bought my truck it had a carbed 350 in it. It originally had a 4.3 but i think it was carbed as well.
I wouldn't worry about pulling through the old pump. Trust me this pump is just plain noisy. I mean people staring at you in a parking lot when you turn the key on noisy. If you have the hi volume (140GPH) like i do you need to run it with a regulator. I run mine with a dead head regulator and it is even worse when its constantly going into relief.
Old Feb 14, 2010 | 06:08 PM
defaria27's Avatar
i have mine hooked up to a malloy switch on my dash..because i took my ecu out. i have hooked up to the basic holley reg. and to the pump i have a summit relay...but when i hit the switch its always on...so i keep hearing that whiding sound.
Old Feb 14, 2010 | 06:12 PM
SeanW's Avatar
I wired my pump through a relay to an ignition hot. Its on as soon as the key is. And its always whining. And its always kind of annoying. Then again you know when your pump aint workin. haha
Yeah that holley regulator is a dead head style(non-return) so at idle you will constantly hear the pump loading up as it goes in and out of relief.
Old Feb 14, 2010 | 11:11 PM
defaria27's Avatar
this is my reg and were located it.....and i did not use the return line...do i have too?
Attached Thumbnails fuel pump problem-3.jpg   fuel pump problem-1.jpg   fuel pump problem-2.jpg
Old Feb 15, 2010 | 09:38 AM
SeanW's Avatar
You can't use a return line with a dead head style regulator. Hence the term "dead head" not to be confused with a regulator that follows around the Grateful Dead. That summit pump has and internal relief valve and so it doesn't require a return line. Your set up is fine. Just noisy, like mine.
Old Feb 15, 2010 | 11:32 AM
defaria27's Avatar
if i decided to just wire my factory one....will give enough pump for my carb...i dont even know what psi to run at,(in new with carb) and if i do that can i use this reg??????????????
Old Feb 15, 2010 | 11:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A carb will want around 6 PSI. More is not better.
Old Feb 15, 2010 | 11:44 AM
SeanW's Avatar
It depends on how much power your motor is putting out as to whether your stock pump will keep up. It certainly will under normal driving conditions. Under extended WOT you could run into issues again depending on your power output.
No that regulator will not work with your stock pump. You need a return style regulator.
Run at about 5 psi at idle. Too much and it will push past the needle, overfill the bowl and flood you out. And it doesn't take much, pound or two out.
Old Feb 15, 2010 | 05:39 PM
defaria27's Avatar
so what should i do? should i keep the summit i bought wth reg and just keep old pump unpluged? or do i hook up factory one....all i know is i the summit one is LOAD. and i have it running all the time..... but my car wont even start right now. everything is new and i might of hooked stuff up wrong....like all my car will do now is crank slow...wont turn over. i hooked up summit hei dist, with a summit box with rev limiter..see i got this car gutted..with factory 305 tpi already out...and just a ruinned harness...so i decided to go 350 carb with out the stuiped ecu. so i had to wire it my self.....so im having some problems.
Old Feb 15, 2010 | 07:33 PM
SeanW's Avatar
Well you can't exactly return the summit one now anyway, its used.
Cranking slow...sounds like a timing issue. Try disconnecting power to your distributor. If the motor cranks fast then you know your timing is way out. Maybe stabbed the distributor 180° out.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
