PULLING MOTOR OUT!
Old Feb 25, 2010 | 06:32 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
PULLING MOTOR OUT!
Hi yall...i got some questions im going to pull my motor out to drop another 305 in it due to a stupid mechanic doing a poor job on my car...my questions is where do i start i got the intake off and all the tpi stuff off where do i go from here...this will be my first motor swap but am excited to take it on to get my baby running again...all help would be greately appreciated thanks.
Old Feb 25, 2010 | 06:38 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Re: PULLING MOTOR OUT!
http://www.autozone.com/autozone/rep...00c15280098d51
also buy a haynes/chiltons manual. label everything (EVERYTHING)and go as slow as you can. take before pictures to reference how to assemble.
Old Feb 25, 2010 | 06:41 PM
Engine: 350 tpi
well i know the tpi stuff front and back and i got all that off i got the distributor off and everthing..i just need the mounts and what else?
Old Feb 25, 2010 | 06:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Exhaust, electrical, coolant hoses, mounts, transmission.
Old Feb 25, 2010 | 07:42 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
torque converter bolts as well as everything Ape listed.
Old Feb 25, 2010 | 07:46 PM
Engine: 350 tpi
well im leaving the transmission in the car tomorrow i will start the process of removing the bolts and flexplate.
Old Feb 25, 2010 | 08:16 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I just pulled my 305 TPI last weekend. Do everything ape said, label everything (electronic connections). I ended up dropping the k-member a few inches so I can reach the back bolts on the top of the bellhousing. Then its straight up...
Old Feb 25, 2010 | 08:49 PM
Engine: 350 tpi
so let me get this straight the connection i labeled today where all the tpi connections and the distributor ones what else will i be labeling?
Old Feb 25, 2010 | 10:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Anything you disconnect.
Old Feb 25, 2010 | 10:28 PM
rabblerouser's Avatar
wiser words were never spoken. absolutely ANYTHING you take off the motor you should label. it makes reassembly so much easier its not even funny. masking tape and sharpie are your friends.
Old Feb 25, 2010 | 10:51 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I'll chime in too. Label everything, and go buy some sandwich bags, and bag up every bolt and label the bags, makes things WAY easier. (I just did that today, taking my motor apart tomorrow, and pulling it out saturday) Good luck!
Old Feb 26, 2010 | 09:55 AM
Engine: 350 tpi
thats exactly what i did with the sandwich bags......and i labled the injectors and all that stuff everything else i put masking tape on and labled it...does anybody know how many botst i have to take off to disconnect the transmission from the motor??
Old Feb 26, 2010 | 03:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Old Feb 26, 2010 | 04:59 PM
Engine: 350 tpi
thanks alot. i really appreciate it.
Old Feb 26, 2010 | 08:36 PM
HCR13's Avatar
Car: 1987 Trans Am
yup. I used masking tape, a sharpie, and sandwich bags too!
Old Feb 28, 2010 | 01:40 AM
jls172008's Avatar
i just recently did my first swap and thought i would let you know its pretty easy as long as you dont have distractions. make sure u dont over tighten the bolts on your chains when you bolt them to the block, just snug will do.
Steve78LT
Feb 24, 2016 12:15 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
