alternator wiring
alternator wiring
ok i swapped engines in my camaro and the alternator i have now is different than the one i used to have. there is only a red and a white wire comming out of my new alternator, but the hookup from the car itself has a red yellow and black wire. anybody know what i can do to hook this up
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I assume you have a 10SI alternator. A large red wire and a plug with 2 smaller wires. Small red is power. The other wire (usually brown) is the field wire.
If you have a newer style alternater with a weatherproof plug then you'll have to check to see what the wires do. One should be marked with an F. That's the field wire required for charging. I don't know what the other wires on the plug are for. I've seen plugs with up to 4 wires on them.
You could just plug it in and see what it does but it may blow the alternator and the newer ones are not rebuildable without unsoldering a bunch of stuff to disassemble the alternator.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
lol thats the thing though i cant just plug it in and see what happens.
ive got a plug in on my alt thats got 2 wires on it. red and white.
and the hookup from the car has got a connector with 3 wires on it. big red, smaller yellow and small black or brown im not sure.
the 2 connectors wont connect they werent made for each other. so ive gotta rewire them together myself but i dunno what goes where and im afraid of screwing things up.
thanks
thanks
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
