427 camero
Old Nov 8, 2001 | 07:37 AM
redneckmilita@aol.com's Avatar
427 camero
I am going to buy a 3rd gen soon as I get out off the service and I want to put a 427 under the hood with a six speed if possible. I would prefeer to use an aluminum block and heads. Does anyone know what I can rob a motor from. The car will be built as a street with a few passes down the strip. Emmisions is not a problem as I will be in PA. I would like to make power from 1500 to around 8000. With somewhere between 450-500 horse and same torque. I have acess to a custom frame builder and I was thinking of building a tubular front end with coil overs. And a cage that ties the front to the rear. I would also like to have a full glass front clip.
[This message has been edited by redneckmilita@aol.com (edited November 09, 2001).]
Old Nov 8, 2001 | 10:12 AM
GTA383's Avatar
The only vehicles I know of that used the aluminum 427 was the 69 ZL-1 camaro and I think some of the 60's corvettes. You would be hard pressed to find one since very few of these cars had them. Then you have to find someone willing to part with it. I think you can purchase an aluminum 427 block from gmpp but they are not cheap.
Old Nov 8, 2001 | 10:49 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
GM performance parts is selling 427 ZL-1
aluminum blocks again.... Good luck trying
to steal one
Old Nov 8, 2001 | 06:09 PM
87RS402's Avatar
You'll never get it by Ca emissions.
Before we get to far into this, if the first part of this post didn't deter you from your desires, are you asking about a big block or small bock 427?
Old Nov 8, 2001 | 06:12 PM
ede's Avatar
ede
look for a rodac engine out of a alky digger or pulling truck/tractor
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 8, 2001 | 06:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Why stop at 427? Pick up a WorldCastings Merlin Lite aluminum block and you can build a 540.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Nov 15, 2001 | 02:29 PM
TexasLT1's Avatar
Car: '92 RS
do they make aluminum 540's? no, I dont think so. thats why he's going with the 427, becuase there are new manufacture 427 engines out there now that for the most part would drop right in. more power to you if you go through with the swap.
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
-'95 Camaro Z28
-'88 Firebird
-'99 Ford Lightning
-'01 Camaro SS (OH YEAH BABY!!!)
-'96 Turbo Eclipse
-'99 Mustang GT
-'01 Nissan Maxima
Losses
-'01 Mustang GT
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
FOR SALE: complete '87 IROC 9-bolt disc brake rearend. rebuilt calipers, powder coated axle housing, painted calipers and backing plate, all brake lines included. needs rotors and driver's side dust shield. The gears are in VERY good condition, low mileage, no signs of wear. make offer
Old Nov 15, 2001 | 03:19 PM
Accually There are a few companies that back aluminum blocks that can go 540+ (donovan). But the car is going to be built for the street. So 550 horse and 550 ft.lbs is what I'm shooting for. I don't want a small black because it is harder to get it streetable with out power adders. I plan on scapping the complete front end and makeing a new one out of tubular steel with costom coil overs. Should also give me more header clearance. Not to mention the weight savings. With the tube front I'm thinking of just using an iron block.
Old Nov 15, 2001 | 07:38 PM
87RS402's Avatar
TexasLT1: Dude, is your sig long enough?
Old Nov 15, 2001 | 08:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I only mention a 540 engine as the biggest easy BBC swap. That's the biggest you can go with a short deck block. Using a tall deck block to go even bigger isn't considered an easy swap into a third gen.
Yes the Merlin Lite aluminum block will go to 540 as a short deck block.
Old Nov 16, 2001 | 04:36 AM
mcconahay37's Avatar
mmmmmm 540. Wish I had the $$$$
Old Nov 21, 2001 | 12:45 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Well you could do what I seen someone do, drop a 620 Donovan straight from a monster truck into a Vega Supercharged and all.
Scary ****
Old Nov 21, 2001 | 09:58 AM
a73camaro's Avatar
There is no "e" in Camaro
Old Nov 21, 2001 | 12:04 PM
SoCo80p's Avatar
alot of people seem to dream with the questions seriously a all aluminum 427 with a 6-speed, you've got to be bill gates to afford that
Old Nov 21, 2001 | 01:57 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I read through the post a few times an I didn't see if that was an aluminum bigblock or smallblock? I want to find an aluminum small block 427, brand new. Is GM Performance selling a big or small block?
Old Nov 21, 2001 | 02:29 PM
Yes it is a big block an for money reasons I am going to use an iron block. I'm going to remove everything that i'm not going to need to ofset the wiehgt of the motor
Old Nov 21, 2001 | 08:03 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Goodluck with the project!
Old Nov 21, 2001 | 10:42 PM
93ND500's Avatar
Try Bill Mitchells(sp) site. He makes an SBC 427 short and long block kits using World Products new blocks. You might find some handy information there.
TABLE SAWS SUCK!!
Loudnproud86
Jul 14, 2016 12:59 AM
Tylermcclinton
Sep 17, 2015 07:50 PM
scottmoyer
Sep 5, 2015 09:33 AM
gruveb
Oct 28, 2001 10:44 PM
327 firebird
Dec 25, 2000 11:22 AM
