Can i swap a ZZ4 crate engine into my 89 RS?
Old Nov 24, 2001 | 07:17 PM
lanyabuddy's Avatar
Hello,
I have an '89 RS Camaro and I was wondering if it is possible to drop a 350 ZZ4 crate engine in there without any major adjustments. Also, what other modifications would i have to do to the rest of the car.(trans, cat , headers, mufflers, gears???)
Happy Holidays,
lanyabuddy
305 TBI RS Camaro, 14 sec@100 mph
Old Nov 25, 2001 | 09:56 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Should be a fairly simple swap. Just about everything should bolt right back up to the new motor(ie, exhaust,tranny).There a few small things you need to decide upon, like keeping it injected or going carb.Carb will require a different distributer.Also,if you want to keep the electric pump or get a mechanical. I kept my electric fuel pump and added a Mallory regulator that would handle the high pressure from the pump.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Nov 25, 2001 | 02:58 PM
Tas's Avatar
Tas
stronger fuel pump, 350 knock sensor, 350 TBI injectors.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 26, 2001 | 12:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ZZ4 heads don't have the exhaust crossover passage that feeds the EGR valve. You'll need to plumb from the manifold/headers to the intake to retain that function. You decide if that is a "major" modification.
The trans will be okay with the standard upgrades, but you might consider a higher stalling converter so the cam can start right to work. Exhaust depends upon what you've done so far - if nothing, do it all. Gears are a matter of what you plan to do with it when you get done. If you don't have them yet, subframe connectors are a good idea.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 26, 2001 | 03:26 AM
lanyabuddy's Avatar
Thanx for your answers, but i have a few more questions?
Is it possible to completely take out the computer and run a carb engine... with the trans, power steering, air con , and some other stuff still functional. How did u guys swap your 350 in the RS?
Happy Holidays,
lanyabuddy
Old Nov 26, 2001 | 04:33 PM
RSpeed's Avatar
The only sensors I pulled out were for the fuel injection and est,(tps,iac,cts,o2,esc module,etc).I left the computer in and most of the harness.
Old Nov 27, 2001 | 02:39 AM
lanyabuddy's Avatar
RSpeed,
Did u keep the TBI running or change to carb cause i'm thinking of completely wiping out the computer runned stuff in the car...I appreciate your tips and i am already in the search of a new ZZ4 ..
Hope you enjoy the holidays,
lanyabuddy
Old Nov 27, 2001 | 10:48 AM
MouseCamaro305's Avatar
in 1989 wasn't the converter lock up computer-controlled?
Old Nov 27, 2001 | 12:42 PM
RSpeed's Avatar
[QUOTE]Originally posted by lanyabuddy:
[B]RSpeed,
I switched over to carb.The computer is still in my car though so I can lock up the converter when cruising down the highway.
Old Nov 28, 2001 | 01:46 AM
lanyabuddy's Avatar
RSpeed,
What size engine is in your car? And what is that converter lockup? Did u change some other stuff like the trans, clutch, and rearend...
Thanx
lanyabuddy
Old Nov 28, 2001 | 01:49 PM
RSpeed's Avatar
<font face="Verdana, Arial" size="2">Originally posted by lanyabuddy:
RSpeed,
Thanx
lanyabuddy
</font>
It is a 350.The lock up converter is like a clutch to where the engine and tranny are turning at the same speed.You should have one in yours if you have a 700r4 tranny.As far as the tranny itself,I only added a Vette servo and higher stall converter.The transmission is still pretty new,but later I will have to add better internals.I am installimg a posi rear with 3.23 gears this weekend.I just put the motor in about a month ago.My brother has an 89 RS and we are building a 383 for it.Should be in by late winter/early spring.
'91 RS, 375hp 350
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,2500 stall converter,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
[This message has been edited by RSpeed (edited November 28, 2001).]
Old Nov 29, 2001 | 12:53 AM
lanyabuddy's Avatar
RSpeed,
Can u post(if possible) a pic of your camaro?
Where's the cheapest place on the net to buy a ZZ4 Crate engine.
Thanx
Old Nov 29, 2001 | 01:20 AM
RSpeed's Avatar
RSpeed,
Thanx
</font>
I can't get them posted right and my website is down.But I will email you some pics. As far as where to get the cheapest ZZ4,I have no idea.Sorry.I got my brand new 350 from ebay.
Old Nov 30, 2001 | 08:35 AM
91-ZZ4-Z28's Avatar
The cheapest place to get a ZZ4 is you local chevy dealer because of the cost of shipping even if the price is a bit higher you will almost always do better localy.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Nov 30, 2001 | 08:43 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
<font face="Verdana, Arial" size="2">The cheapest place to get a ZZ4 is you local chevy dealer because of the cost of shipping even if the price is a bit higher you will almost always do better localy.</font>
NO WAY!!!!!!!!
that is DEFINITELY not true!
it cost me a hundred bucks yo get my engine shipped to me.
i paid 2000 bucks,and teh local dealers couldnt TOUCH that price.
and i am friends ith a local parts manager that gets me everything at "cost" (wholesale) and it wasnt close.
try www.paceparts.com
they are the BEST when it comes to GM Performance Parts.
-brian
1991 Camaro RS
GMPP 350 HO crate engine - Holley TB, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Nov 30, 2001 | 05:29 PM
Chevy83Z28's Avatar
The prices on the www.paceparts.com site seem the same as in Jeg's (for the GM crate engines at least.)
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
