Brackets with engine swap
Old Mar 11, 2010 | 08:35 AM
83T/A's Avatar
I have an 83 T/A that came with the 305.Bought the car with no engine.Previous owner sent the brackets that went with the 305.New engine is an early 70's model 350.I can't seem to get the belts to line up correctly,especially the alternator belt.NOt sure if I am missing something,have the belts routed wrong or what.I have already been through 3 alternator belts and I am getting really frustrated.Any help would be appreciated,even pics if possible.Thanks.
Old Mar 11, 2010 | 01:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Any chance you can post a photo of what you've got and the problem you're having? Are you using the alternator that came with the engine, or the one that came with the car?
Old Mar 11, 2010 | 01:55 PM
83T/A's Avatar
Re: Brackets with engine swap
Well,I would send some pics but i have it apart right now.The main problem I have is between the alternator and the water pump pulley.The alternator is brand new and is supposed to be the correct one for the car.It's possible that I have the belts routed wrong.I didn't have a diagram.There is no smog pump on the car,just alternator,water pump,power steering and A/C.The pulleys are correct for the car and there doesn't seem to be any difference in the blocks.
Old Mar 11, 2010 | 03:37 PM
five7kid's Avatar
Where did the brackets come from, then?
Which side of the engine is the alternator on?
Old Mar 11, 2010 | 03:53 PM
83T/A's Avatar
The brackets came with the car,supposedly off of the original 305 that was in the car.The alternator is on the passenger side of the car.
Old Mar 11, 2010 | 04:18 PM
five7kid's Avatar
I've looked for a decent picture of them, see if this helps.
https://www.thirdgen.org/forums/atta...r-p0005492.jpg
That is without air conditioning.
Old Mar 11, 2010 | 04:40 PM
five7kid's Avatar
More:
https://www.thirdgen.org/forums/atta...rockerarms.jpg
If those don't help, I'll try to get a pic of mine this evening.
Old Mar 11, 2010 | 04:52 PM
83T/A's Avatar
That looks like what I have.I am not sure if I am supposed to have a long or short water pump.I have a long on there now,tried a short and it didn't seem to work either.I have searched for a belt routing diagram but have been unsuccessful.I have found a used serpentine system really cheap and am about to the point to just forget the two belt system.
Old Mar 11, 2010 | 05:42 PM
five7kid's Avatar
Long water pump.
Old Mar 11, 2010 | 07:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you use the serpentine system, make sure you get a reverse rotation water pump to match.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
