tpi/lt1/ls1 cold air intake idea
Old Mar 14, 2010 | 12:09 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
tell me what you think, i had this good idea after looking at my car. imagine first a car with the grfx off of a 90-92 camaro. then moce the battery to the back of the car and run a intake ofer to where the battery used to be and cut a large hole for the intake to run through and put the filter below the battery tray. then box it off to keep off water and somehow pull air in through the "fake" vent in front of the wheel. so that vent would be a intake scoop.
so what do you guys think?
oh and to top it out, the long intake tube would sound great pulling in that air!
Old Mar 15, 2010 | 09:44 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: tpi/lt1/ls1 cold air intake idea
You're chasing a snipe. First, that tiny scoop won't feed your stock 305 enough air. Second, there's no need to box off that area. The rest of your proposal is very much like what is commonly done to many vehicles. Stick the tube through the hole you cut in the tray, attach the K&N cone to that, and you're done under the car. The rest of your work is entirely under the hood from above. No worries about rain, just don't try to cross any floods.
Old Mar 16, 2010 | 10:54 AM
Car: 02wrx/88 rs
well i was thinking, what if the vent was sylishly enlarged? and italowed more air? or if you y'ed it and half went to one side and half to the other?
Old Mar 16, 2010 | 12:04 PM
Stephen's Avatar
Car: 87 GTA
What vent? You gonna pull your turn signals out & use that?
Just drop the filter down there & be done. I know of a local LS1 3rd gen that did that.
Old Mar 16, 2010 | 12:08 PM
Car: 02wrx/88 rs
i always get envious when i see a ls1 in a 3rd gen lol.
no im talking about the vent in front of the wheel on the camaros. just an idea.
Old Mar 16, 2010 | 12:09 PM
Car: 02wrx/88 rs
i just like the idea of using the stock scoops and making them functional for whatever purpose
Old Mar 16, 2010 | 12:16 PM
Stephen's Avatar
Car: 87 GTA
Check with Neil. I think he turned his scoops into brake cooling ducts. No reason they couldn't be used as intakes, although I think it might be kinda "pointless" to fab up the ductwork to do that, when it will function just fine without it.
Old Mar 16, 2010 | 01:24 PM
Car: 02wrx/88 rs
yeah i see where you are comming from but. i drive my car all year round. even in the pourng rain. so i dont wanna hit a puddle and suck it up so that why i was thinking of boxing it off and using it
Old Mar 16, 2010 | 01:36 PM
Stephen's Avatar
Car: 87 GTA
I wouldn't worry about that design too much. If you are? Put a flat plate under it, to act as a plash shield. Problem solved.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
