A 350 with a 5 speed? Is it bad? Or better!
Car: 1988 camaro Iroc-z 350(stick)!
Transmission: manual/ 5 speed.
Ive got a 1988 iroc-z that was a 305 stick, that a past owner had put a 350 in it. It has a whine when you put the clutch in mainly in first gear. It whines when you release it slowly. Could this be that it need a new performace clutch or do i need a new trans to accomadate the 350? Im going to put a 383 in it, Is that too much for that trans?
Car: 85 berlinetta LG4
Engine: original rebuilt 305 bored 30 over
Transmission: original rebuilt 700r4
Axle/Gears: rebuilt 10 bolt 3.08's
Re: A 350 with a 5 speed? Is it bad? Or better!
first you need to find out wheither you have the stock t5 or the better t56 5 speed?the t5 will hold up to a 350 if you dont drive it to hard all the time,but the t56 is a lot more foregiving when it comes to running hard down the road.IMOP if you upgrade to a 383 plan on upgradeing to the t56 as well but thats just my 2 cents.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
T5 will hold for awhile with a 350 if it's babied. T5 will NOT hold up to a 383 for very long.
You would need to get a T-56 to hold up - it's the 6 speed from a 4th gen. You'll also need new crossmember and some other goodies to put it in your 3rd gen.
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
is it whineing when your sitting at a stop light or sumthing with your foot on the clutch and the car in gear and makes noise untill the clutch is fully ingaged. if so it could just be a pilot bushing.
T-56 is a 6 speed, not a 5 speed
sorry that was my bad meant to say the world class t5,was talking to buddy about his t56 swap and got them mixed.ill be the first one to say it
lol.
lol. Thread Starter
Why wont the t-5 trans hold up? Even if i put a performance clutch in it and put some Royal Purple syncromesh in it it still wont hold up to blown mustangs away on a daily basis? What technically will go wrong with the t-5?
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
It wont hold because its a weak transmission, there is a reason GM never put 350's and T5's together. The clutch and "Royal Purple Syncormesh" wont make a difference.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
1992 Trans Am
Aug 8, 2015 08:16 PM
