vette motor into GTA
Old Mar 22, 2010 | 04:45 PM
Pug89's Avatar
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
I am looking at swapping a 350 tpi out of a 1986 corvette into a 1989 GTA that has a blown 350 tpi in it. the motor does not have a wiring harness with it other than that it is complete. How much of a pain is this going to be to swap in? or will it just bolt up? Thanks for the help
Old Mar 22, 2010 | 05:26 PM
Stephen's Avatar
Car: 87 GTA
Re: vette motor into GTA
EDIT: I put WRONG INFO HERE! I'm not trying to hide what I said, but getting rid of the wrong info being posted on TGO for future readers to read.....
Last edited by Stephen; Mar 22, 2010 at 05:44 PM. Reason: my dumba$$ info DELETED!
Old Mar 22, 2010 | 05:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'89 f-body TPI is MAF. Only difference from '86 TPI is the deletion of the cold start injector.
'86 Vette could be either cast iron heads (early '86) or aluminum ('86-1/2). In either case, it has the "pre-'87" intake mount bolt pattern (angles on the center two bolts on each side). If you just swap in the entire Vette engine/TPI, this won't be a problem - but you'll need to do the harness and ECM as well. You can keep the '89 ECM by swapping the plenum, or just not connecting the cold start injector (using the '89 harness, obviously).
You'll need to remove the Vette oil pan and pump, and install f-body parts. Your '89 pan will fit, but you might as well get a new oil pump. Swap over your '89 front accessories as well.
Overall, it's a bit of a downgrade (lose roller lifters), and not emissions-legal. Difficulty-wise, it won't be that hard, regardless of how you go about it.
Old Mar 22, 2010 | 05:42 PM
Stephen's Avatar
Car: 87 GTA
DOH! Your right. I should know that, since I pulled the MAF off my old 89 GTA & it has become a spare part.
Old Mar 23, 2010 | 10:17 AM
Pug89's Avatar
Engine: 5.7 TPI L98
five7kid please read
so your saying if i take the tpi set up off my GTA motor and put it on the vette motor i wont have to change the harness and ecm?
Thank you for the help it is much appreciated. Is there anything else i should know or replace.
Old Mar 23, 2010 | 12:36 PM
five7kid's Avatar
Well, I talked too much. It is much simpler than I made it sound.
You can take the harness off of your 305 TPI and set it aside in the engine compartment, pull the engine and TPI complete, do the change-overs for the Vette engine (oil pan & pump, accessories, exhaust manifolds - the Vette exhaust manifolds won't fit in the chassis), install the 350 in your GTA, and reattach the harness. The cold start injector just won't have a connector on it.
You'll need the 350 knock sensor module. The knock sensor itself should still be on the engine in the passenger side water jacket drain hole.
If this engine has aluminum heads, the EGR tube will need to be routed to the exhaust manifold as well. I'm not clear on the details, but I believe the A.I.R. tubes are different - but they should transfer over from the Vette exhaust manifold to your GTA manifold. If you have headers - fabrication will be required.
Old Mar 23, 2010 | 01:45 PM
Pug89's Avatar
Engine: 5.7 TPI L98
five7kid thank you for all the help. If while i am doing this and i have any questions would be ok if i private messaged you? Thanks again.
Old Mar 23, 2010 | 02:52 PM
five7kid's Avatar
You might want to post public if you want to be assured of a correct answer. . .
Azrael91966669
25
Jun 20, 2017 04:04 AM
The_Phoenix
Feb 4, 2016 07:10 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
NBrehm
Aug 5, 2015 07:57 PM
