WHAT HEAD GASKETS TO USE!!!!!
Old Apr 14, 2010 | 03:43 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Hi guys i am going to drop a 350 in my 87 iroc...i removed the heads that came with this motor to put my lb9 heads on it...but i had a question what head gaskets do i get since the block is the 3970010 block i dunno exactly what it came out of so i dunno which head gaskets to buy..thanks sorry for the dumb question...
Old Apr 14, 2010 | 08:52 PM
Engine: 350 tpi
Re: WHAT HEAD GASKETS TO USE!!!!!
So possibly just a set of 350 head gaskets should do the trick?? cause i just fitted the ones that where on the 305 and they where too short.
Old Apr 14, 2010 | 10:22 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Before choosing gaskets, first get a straightedge and some feeler gauges, and determine how far your pistons are above or below the decks at top dead center. Gaskets are available in thicknesses from 0.015" to over 0.070", and your goal is to have the heads about 0.040"-0.045" from the pistons.
Old Apr 14, 2010 | 10:37 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
If you're talking about brand/type, I say go with Cometic gaskets. They are the shizz. As long as you don't blow them out, you can re-use them should you ever have to remove the heads.
Old Apr 15, 2010 | 11:24 AM
Engine: 350 tpi
How exactly would i do this..as this is my first 350 swap so im kind of new to this stuff. thanks
Old Apr 15, 2010 | 12:15 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Ok, I have a knowledge bump question now. Why are you putting LB9 heads on instead of using 58cc heads? Won't this severely cut down on the movement of airflow through the engine?
Old Apr 15, 2010 | 12:17 PM
Engine: 350 tpi
I thought the 1081 heads where 58cc??
Old Apr 15, 2010 | 01:48 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I think the other person meant 58cc aftermarket heads. But 081s are around 55cc stock.
Old Apr 15, 2010 | 01:54 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
First put the straightedge on the deck, across a cylinder, and turn the crank, watching to see if the piston actually touches the straightedge.
Forgot to mention, you'll need a degree wheel. And it's easy to look up the instructions for finding TDC. It can be done without buying a dial indicator.
Anyway, put the piston at TDC, and if it's touching your straightedge, then let the straightedge rest on the piston, and use your feeler gauges between the straightedge and the deck.
If the piston is below the deck, It could be as much as 0.050" down. Sad, but possible.
Get started and it'll become obvious. It's one of those things.
Old Apr 15, 2010 | 07:23 PM
ibmtech's Avatar
Car: 1987 IROC-Z
I believe the L98 Corvette with a 350 TPI Uses 58cc factory heads
Old Apr 15, 2010 | 07:59 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Yeah, they're nominally 58, but due to production tolerance, one head could average 57c, and the very next one could average 59cc. So, a 57cc head, with a light clean up resurfacing of just 0.006" is 56cc. If you have 59, then mill it 0.018" to get to 56. Come on, guys, think it through. Whatever the head is reported to be, subtract 2cc to be safe. If it's 40 years old, it's probably been rebuilt a couple of times, so subtract another 2cc. Better to have your real SCR be 0.25:1 less than you think, than to have it wrong the other way.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
