what are my options?
Old Apr 16, 2010 | 05:23 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
hi again... ive been fighting problems with this 383 my friend built for months. Ive got it running pretty good accept for the stumble at WOT. Come to find out a cam lobe went south. Im done with this engine and its time to move on.
What are my options that will go in without ALOT of work?
These arent my only choices, but i was thinking maybe a 454, an lt1, or a ls 327. I dont want another carb, im done with that also.. time for fuel injection. I have a t56 that i will mount behind the new engine. Im willing to change the input shaft for the ls engine, but im just not sure what else must be done to install it.. Thanks guys! What would you put in it?
Old Apr 16, 2010 | 09:32 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: what are my options?
You can keep looking into those options, but I'd suggest you start by investing just $500 into converting your current 383 to a hydraulic ruller set-up. Take a look at this:
http://www.competitionproducts.com/H...info/CL110245/
Doing this and switching to EFI is still cheaper than any of your other options.
Old Apr 16, 2010 | 09:48 PM
Engine: 383 Stroker
Transmission: t-56
What are my options for EFI?
Old Apr 16, 2010 | 10:27 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The cheapest and easiest is to find a junkyard dually pickup that's been totalled, and get the throttle body off the 454. Then get the rest of the TBI system from an '87-'95 pickup 350, and plan on a custom prom chip. You'll need to address the fuel pump situation, TBI needs 12-15 psi to work right. Holley offers a TBI to 4-bbl adapter plate.
Old Apr 16, 2010 | 10:30 PM
Engine: 383 Stroker
Transmission: t-56
I was really asking about fuel injection, not tbi. That would choke my 383.
Old Apr 16, 2010 | 10:34 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
TBI is injection, you didn't specify multi-point / multi-port, whichever.
The cheapest option there is to start with a Stealth Ram, 30# injectors, and start with the stock '90-'92 TPI computer, or a MegaSquirt.
Old Apr 16, 2010 | 10:43 PM
Engine: 383 Stroker
Transmission: t-56
Thats what i was thinking also. How much would that run?
Old Apr 17, 2010 | 07:18 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you can't find any good deals on any used parts, the Stealth Ram runs $326, the fuel rail kit with AFPR runs $240, the injectors run $260-280, and Hawks should sell you a used harness for around $200.
Old Apr 17, 2010 | 01:20 PM
Engine: 383 Stroker
Transmission: t-56
So i should be all in at under 1k... some have told me i could use some ford injectors, do you know which ones?
Old Apr 17, 2010 | 02:01 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That's what I was pricing, the 30 #ers for a ford 5.0L H.O., '86-'95
Old Apr 17, 2010 | 04:15 PM
Engine: 383 Stroker
Transmission: t-56
is it possible to use the wiring harness from an lt1 on my sbc?
Old Apr 17, 2010 | 04:44 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
what about wiring the distributor?
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
