Finally Swapping out my V6!!
Old Jul 19, 2010 | 09:49 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
After selling my 87 camaro 4 years ago, I'm getting it back from my brother. I drove it the other day and can't believe I left the v6 in there! I have access to a muncie 4 speed and a 3.73 rear for cheap or free so I plan on putting them in. Also, I have a set of good unported vortec heads, a GMPP carb intake, and a 350 or 327, my choice. This won't be an all out racecar, I'm basically building it on a bare bones budget for a play car. I want it reliable though.
My questions are:
1- Would 3.73 gears work foor with a M21 4-speed? Where would that put my highway cruising rpms's? Can I put a M21 in a 3rd gen?
2- I want to build it for pump gas (92 or 93 oct) and also leave the option open to put a procharger on. What CR should I be shooting for? Any other considerations? Can I put a procharge on a carb'ed car?
3- Is a carb an ok way to go for this car? The MPFI obviously won't work on a V8 so i was thinking about gettign rid of the computer all together and throwing the carb on. i don't want to spend a ton of money or time (I don't have much of either) into tuning an injection system.
Old Jul 19, 2010 | 02:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It would work. Use the calculator tools available.
https://www.thirdgen.org/calculations
You can Procharge a carb'd car. Talk to them about CR.
Do you have any kind of emissions inspection or testing? Technically, non-computer carb isn't legal on your car (and Procharge doesn't do computer carbs - I asked).
Old Jul 20, 2010 | 08:03 AM
Axle/Gears: 4.10
Re: Finally Swapping out my V6!!
I won't have to worry about emissions since the car will be driven under 5000mi/year.
Yea I found those calculators yesterday and started playing around with them. I may end up going with the 327 and m21 since their basically free but down the road I may want overdrive. Would a flywheel, clutch, & pressure plate from a m21 work on a T-5 or T-56?
Also, my T-5 I have in the car now is from a 84 v6 (I think). Can I get a v8 bellhousing, a new flywheel, and clutch and use that trans? How much horsepower would it take?
Old Jul 20, 2010 | 08:52 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
The clutch wont work the flywheel and pressure plate should work
Old Jul 20, 2010 | 11:32 PM
five7kid's Avatar
You can use an S10 clutch disk with V8 flywheel and pressure plate.
Just don't make any more power than the V6 does and the transmission will be fine.
Old Jul 21, 2010 | 12:17 PM
Axle/Gears: 4.10
So basically I better swap out the trans, right? I'd really like to have overdrive but even the WC T-5's are only rated for 300hp and T-56's are too expensive. I have a Muncie 4 speed I can put in. How difficult would that be?
Old Jul 21, 2010 | 01:27 PM
five7kid's Avatar
The primary issues with the Muncie are the lack of torque arm mount, and crossmember mount location. Spohn can cover you for both with a swap crossmember and crossmember-mounted torque arm. http://www.spohn.net/shop/1982-1992-...nsmission.html
Old Jul 21, 2010 | 02:19 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
Isnt this the truth
Hell I went 12s on a 4.3 clutch lol but it was new never drove on and then when tried to make second pass it was done lol
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Polo Z03
Sep 10, 2015 06:43 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
