383 stroker keeps blowing head gaskets.
Old Jul 24, 2010 | 05:22 PM
dthquazi's Avatar
It is a 98 l31 motor with the stock vortec heads. Compression should be around 10:1. I have replace the head gaskets 3 times. The first two I was using the arp studs. This last time I used bolts. My next option is to have the heads shaved again but I don't want to dump a bunch more money into this if it's not worth it. Any help please.
Old Jul 24, 2010 | 06:11 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 383 stroker keeps blowing head gaskets.
Have you checked to make sure the block and heads are compltely and perfectly flat?
Old Jul 24, 2010 | 06:27 PM
dthquazi's Avatar
When I had the block machined they did the block and head surface. I took the heads to a different shop to have the heads checked. That shop said they were good(flat and not cracked). This is driving me nuts. Is there a way to check the block and heads myself.
Old Jul 24, 2010 | 11:12 PM
built91Z28's Avatar
Straight edge and a set of feeler guages. And you need an actuall straight edge, not just some piece of metal.
Old Jul 25, 2010 | 07:36 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
What gaskets were you using?
Old Jul 25, 2010 | 02:20 PM
dthquazi's Avatar
I am using the felpro 1010 I believe. I am looking for some feeler gauges and a good straight edge as we speak.
Old Jul 25, 2010 | 04:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Well, using FelPro gaskets isn't helpful to diagnosing this. If you had typed Chinese gaskets, that might have been helpful.
Are you running nitrous or boost?
Old Jul 25, 2010 | 05:17 PM
dthquazi's Avatar
No boost or nitrous. I have just taken off the passenger side head and cleaned it up. I am unable to fit a .0015 feeler under any spot. I know it has been discussed other places but what's a good way to clean surfaces. I have been using a razor blade and lacquer thinner. I will have to wait to pull the other side off until tomorrow.
A little more about the problem... I get it all assembled and then start it up. Once it reaches a good temp, I re-torque the head bolts. I run it again to a warm temp and check. Each time I pull the manifold-to power brake vacuum line and it sprays water. Once I pull the intake manifold there is not an abundance of any fluid in that area.
Old Jul 25, 2010 | 05:55 PM
vangogh4560's Avatar
Car: 1987 camaro lt
Engine: soon 383
is it all ways the same side? sounds more like a cracked head magnaflux the heads for 30$ id start there
Old Jul 25, 2010 | 06:39 PM
dthquazi's Avatar
I'm not sure how to tell which side it is coming from. Since it is Sunday I am gonna take them in tomorrow.
Old Jul 25, 2010 | 08:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
FelPro claims those don't need re-torquing. But the right way to do it is to get it up to temp, then let it cool, not re-torque while the engine is still warm.
Old Jul 26, 2010 | 08:03 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Also, you need to drain the coolant if you're gonna loosen all the head-bolts before re-torquing any of them. If you don't want to drain the coolant, just do 1 bolt at a time.
If you get any coolant between the gasket and the decks, then re-torque it, the coolant now has a permanent escape path.
Old Jul 26, 2010 | 10:30 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Compression too much? If you have had heads shaved the compression is going to get higher and higher because your piston gets closer to the heads.
I love cast iron worked heads(I guess I am just a believer about old school stuff)
My dad has had a 8 second car that was a street car and ran spray and boost since 1993 and its got cast heads on it with copper gaskets and never had a problem
Is your temp getting higher then 210?
Old Jul 26, 2010 | 02:11 PM
383TBI's Avatar
Car: 87 Chevy Short Wide
Engine: 383 Vortec TBI
How are you determining the gaskets are blown.When the heads are removed can you tell by looking at the gasket if its blown.Is it blown between cylinders or do you have milky oil on top of heads.I thinks these
guys need to know that info before they can throw you some ideas.Good luck
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
