305 to 350 swap
Old Oct 30, 2010 | 05:37 PM
jragz33's Avatar
305 to 350 swap
i have a 83 trans am with a 305 i just pulled out, and i have an old 350 my uncle used in his camaro while he was racing at the track, i am pretty much not using anything that was used on the 305, the 350 will have a carburetor. i have 2 concerns, one being motor mounts, im not sure if its the same block or not, and second is the transmission, what do i do i need some guidance please!!!
Old Oct 30, 2010 | 08:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Take out the 305, put in the 350.
(BTW, this isn't a "Pontiac engine swap" topic. The 305 and 350 are small block Chevy engines, not Pontiac engines.)
Old Oct 31, 2010 | 01:15 PM
jragz33's Avatar
Re: 305 to 350 swap
so the motor mounts will be ok to use? is the block the same? i measured the mounts off both the 305 and the 350 and they are very close. it is off by one inch, so that means the motor will be one inch closer to the fire-wall, are there brackets or something i should use?
Old Oct 31, 2010 | 01:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350 swap
Use all the mounts and brackets off the 305.
Old Oct 31, 2010 | 01:37 PM
jragz33's Avatar
Re: 305 to 350 swap
the mounts will work, now as far as headers, thats going to be a tight squeeze is it not? am i going to have to make a set of headers?
Old Oct 31, 2010 | 05:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 to 350 swap
The same headers fit either engine, there are about a dozen different ones you get get off the shelf.
Old Oct 31, 2010 | 06:03 PM
jragz33's Avatar
Re: 305 to 350 swap
ok so i shouldnt have to worry about space between the firewall or anything else? because the block is the same so i would imagine everything is similar...
Old Nov 1, 2010 | 01:34 PM
five7kid's Avatar
As long as your uncle had a Chevy engine in his Camaro, yes.
Old Nov 1, 2010 | 07:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 to 350 swap
If you are saying that you have headers already on the uncle's Camaro 350 engine, they will only fit if that Camaro was a 3rd gen (only 3rd gen specific headers will fit a 3rd gen car).
Old Nov 2, 2010 | 09:35 AM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
Re: 305 to 350 swap
No what he is saying is that because your Uncle had the engine in a Camaro everything will swappable with no modification to the engine bay/firewall or any of that shenanigans. Since the 305 and 350 use the same motor mounts, the third gen 350 will go into a third gen without any effort outside plugging it in and installing it. Fbody is Fbody is Fbody. ;D You need not worry about headers or other dodads since the third gens were made practically the same aside from the body styling.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
