swap my 305 tpi/auto trans, to 350/manual?
Old Nov 23, 2010 | 11:32 AM
xFeveredx's Avatar
Car: 1989 Pontiac Trans Am
Engine: 5.0 TPI LB9
Axle/Gears: 10-bolt 2.73
I have a 1989 trans am, 305 tpi, with auto trans. How hard would it be to swap for a 350 with a manual? does the body come with the mounting bracket for the clutch or will i have to make one?
Old Nov 23, 2010 | 02:13 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: swap my 305 tpi/auto trans, to 350/manual?
Assuming you're talking about a T5, It's all a bolt-in with the exception of needing to cut your transmission tunnel and the hole in the firewall for the master cylinder. For a T56, if you get the right parts, it's mostly a bolt-in, but will require a new crossmember.
The clutch, brake & gas (or brake & gas for an auto) is all one assembly, so that's a bolt-in swap.
Old Nov 23, 2010 | 03:58 PM
xFeveredx's Avatar
Engine: 5.0 TPI LB9
and how would i find out if its a t5 or a t56?
Old Nov 23, 2010 | 07:22 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
t5 is a 5 speed
t56 is 6 speed
Old Nov 24, 2010 | 08:21 AM
Jim85IROC's Avatar
Do you have the transmission already, or are you just asking how to identify those transmissions?
Old Nov 24, 2010 | 10:55 AM
xFeveredx's Avatar
Engine: 5.0 TPI LB9
i have the 5 speed auto transmission in my car already. i didnt know that was how to differentiate them though, learn something new everyday!
Old Nov 24, 2010 | 12:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
5 speed automatic?
The stock automatic transmission was 4 speed, or you could say 3 speed plus overdrive.
Or, did you mean 5 speed manual? In your original post, you indicated you have an automatic transmission.
Old Nov 24, 2010 | 01:47 PM
xFeveredx's Avatar
Engine: 5.0 TPI LB9
im confusing myself, sorry guys.
i do have the stock auto 4 spd trans in my car
and i would like to swap for a manual 5 speed
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
