Turbo'd sbc
Old Dec 2, 2010 | 07:56 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Turbo'd sbc
Hey guys, iv decided to retire my old 305 and wanted to build a new 350 or 355. Then my brother put his two cents in. I thought id do a bit of research starting here. I would like any and all help i can get, comments concerns what to do or what not to do. Why it would be a great idea or a dumb one. Anything at all will help.
Thanks guys!
Old Dec 2, 2010 | 10:20 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Turbo'd sbc
You want good exhaust flow, so stay away from Vortec heads. You won't want to run a high compression motor and you'll probably want moly or steel rings. I can't be of much help but someone can correct me.
Old Dec 3, 2010 | 12:38 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: Turbo'd sbc
...Vortec heads are excellent and should NEVER be avoided if you want power on the cheap. The exhaust ports have no flow problem, the issue is that they cant keep up with the intake ports which have excellent numbers. This can be rectified with 1.6 exh valves.
Old Dec 3, 2010 | 04:22 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo'd sbc
Alright guys thanks for the info! Still looking for more insight please anyone.Also would like to know nice cam to run? I have a Thumpr cam sitting around was going to use that but have no idea
Old Dec 3, 2010 | 06:44 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: Turbo'd sbc
As I understand,the Thumpr cams get their "thump" from a narrow lobe seperation,in otherwords LOTS of overlap,not a good choice for forced induction.
I have personally never done much with turbos,mostly out of fear.I have seen several people have great success with them.I've seen several others create some enormous piles of broken parts.
I think turbos today are much like nitrous was 30 years ago,people don't get a good understanding of how to tune it,and end up with catastrophic results.
There are several here with turbo combos,seek out their wisdom,and you will end up with a great combo.
Old Dec 4, 2010 | 11:35 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo'd sbc
Alright thanks, Im not looking to put tons of boost just some, it will be for the most part a everyday driver. Yes i am aware of the heavy overlap, but id hate to see a camshaft go to waste :/ i didnt think it would be so much as a great idea but, what would happen if i did use it?
Old Dec 13, 2010 | 05:55 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo'd sbc
i see it has been a few days and still no more posts. Please Guys anything and everything will help. Even to just talk about the idea Thanks!
Old Dec 13, 2010 | 08:06 PM
sniperperforman's Avatar
Car: 1985 twin turbo camaro/1998 t-S10
Engine: 427 TT small block 14-30 psi
Transmission: 4l80E
Axle/Gears: moser m9 4.11
Re: Turbo'd sbc
ok cypris09 im a pro engine builder and have been useing turbos for a long time. im currently build a twin turbo 408 sbc. thats going to see over 30 psi of boost. 1st thing is to keep you compression ratio 9.1 or under i would play it safe and go 8.5:1. you probley looking for about 7-10 of boost. probley single turbo. that pretty respectable. i recomend a after market 23 degree head for what your wanting. racing head service, has some nice castings stay away from there pro lightning heads. and go fro the pro action stuff. the next thing is to make sure your using a steel rotating assembly. i also use forged pistons. you see im a durability builder i like my engines to take a beating and stay together. Your exhaust is a small playin factor how ever you do want it to flow well. i would also consider cutouts they work well when your looking to use some boost for racing. give me a e-mail if you have any other questions.
Old Dec 13, 2010 | 08:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Turbo'd sbc
Depends on how much power you want to make and how much money you want to spend
stock block 4 bolt mains can hold a fair amount of power. Keep it all forged 355 and 9 to 1 comp with aluminum heads. 10-15psi on pump shouldnt be out of the question and REALLY make things interesting when you stomp on the gas.
Old Dec 15, 2010 | 05:35 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo'd sbc
Actually guys im looking at a twin turbo kit want to kick around 10-15 for the boost.but yeah thanks will deff give ya an email if i need help
gixxer92
May 18, 2017 11:20 AM
cheesehomer
Dec 31, 2015 08:48 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Bradsaundry
Oct 7, 2015 04:35 PM
bjpotter
Oct 4, 2015 07:48 PM
