engine swap
Old Dec 3, 2010 | 10:11 PM
loren 1980's Avatar
engine swap
Has anyone ever tried to stuff a 454 in place of a 305? thinking of this swap for my 92 firebird, can it be done?
Old Dec 4, 2010 | 08:58 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: engine swap
Anything can be done, use search button theres plenty of threads on BBC swaps. Have to modify the K member for headers though or buy a tubular K member
Old Dec 4, 2010 | 10:46 AM
gtanut's Avatar
Re: engine swap
it is a very easy swap no need to do anything to the k member use small block mounts drops in like the small block headers are kind of pricey
Old Dec 4, 2010 | 01:34 PM
dcollins's Avatar
Re: engine swap
Can anyone give me some advice. i am looking to replace my engine 5.0 305 TPI on 88 firebird trans.. I am not doing it myself but taking it to a shop. I was reading some people saying i should upgrade to 5.7 TPI. Any suggestions and what type of mods should i have them do. I dont have a ton of money looking to spend about 2000-3500 but i just dont want to spend the money and find out for an extra couple hundred bucks i could have gained alot more. I am a rookie so break it down a little bit for me. If you know of any websites or shops to recamend please let me know.
Old Dec 4, 2010 | 02:12 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: engine swap
You could do that, but I would just use a manifold and carb, and call it a day. Also I would search and search for information. You will end up spending more money if you don't do the research ahead of time.
Old Dec 4, 2010 | 02:19 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
Re: engine swap
How much of a gain could one expect switching the top end to carb on a 305 ?
Old Dec 4, 2010 | 02:21 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: engine swap
Your not going to gain anything but simplicity with a carb. And some carbs like quadrajets can still get decent mpg and have the secondaries to really give you the power. I myself would go with a carb, but you can go FI too.
Old Dec 4, 2010 | 02:49 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: engine swap
Carb is cheaper then FI once you start building a motor. I have heard good and bad things about TPI, for a street car I guess it's a good thing.
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: engine swap
with a budget around there i would think best bang for your buck is a vortec 350 motor
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
