motor-change process?
Old Dec 12, 2010 | 09:58 PM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
Taking into consideration that I wont know when exactly my L03 will give up on me, I've heard the term motor-change process mentioned on this site alot. Now i think i have it down. You have to go through a motor change process if you're doing a complete swap? i.e. if i find a 93 camaro donor, i have to install everything from cpu to smog equipment. Correct?
My main question is if i just want to get a short block from maybe a 92 camaro z28 tpi at a junk yard, do i have to go though that motor change process if its just the short block?
I do plan on keeping it TBI with all the stock smog equipment on it.
But if i do have it wrong, then what exactly is the motor change process? and how do i go about it? Thanks for the help!
Old Dec 13, 2010 | 02:35 AM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
Re: motor-change process?
I'd appreciate any type of info...
Old Dec 13, 2010 | 03:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's referring to the steps you need to go through in order to install an engine other than the factory or certified replacement in California for the purpose of emissions inspection and testing.
Old Dec 13, 2010 | 08:35 PM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
is that only for california?
also when they say you cant use a truck engine in a car, do they mean you cant use a commercial truck engine or a passenger truck like silverado?
Reason is because i though about that "budget TBI buildup" sticky but i didnt want to do it if we're not even "allowed" to by law. I dont require emissions testing but i still wouldnt want to do just in case they change the rules on me and start testing us in my area.
Old Dec 14, 2010 | 01:06 PM
five7kid's Avatar
California is the only state of which I'm aware that has a "motor change" procedure.
The rest of what you're describing is EPA stuff that applies to all 49 states (California has to meet at least the EPA requirements, but is allowed to impose even stricter requirements - no other state is allowed to do that). You can't legally use a Silverado engine in a passenger car anywhere in the U.S. The "budget 350 TBI" is not an emissions legal swap.
Old Dec 14, 2010 | 02:24 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I think NJ you can't swap in an older motor or larger displacement motor.
Old Dec 14, 2010 | 03:59 PM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
i see... well it seems that the easiest thing for me to do is just rebuild the l03... I'm not really that power-hungry (although buying a 92 z28 long block is still something i am pondering). I am more obsessed with the looks of the car than the engine. Currently it has 116k miles so it may still last another 5-10 yrs.
I do have one more question... why is no other state allowed to impose stricter requirements like california?.
thx for your replies.
Old Dec 14, 2010 | 04:01 PM
five7kid's Avatar
Right, because NJ adheres to EPA requirements.
You can put a larger certified passenger car engine as long as it is the same year or newer than the chassis, and you install all of the equipment the certified vehicle had.
Old Dec 14, 2010 | 04:03 PM
five7kid's Avatar
Good question. The best answer I have to that is California has worse problems than the rest of the country.
Old Dec 30, 2010 | 04:36 PM
z28m8's Avatar
Car: '91 camaro z28,imsa widebody
Engine: 383 ci l98,lt1 induction
Transmission: race built 700r4 , ratchet shifter
Axle/Gears: 342;1 detroit true trac diff
hi guys,
im putting a 383 stroker in my 350,
is it easier to remove just the engine or engine and 'box from my '91 camaro, do they both fit through the engine bay???????
also how do i put pictures of my car on this site??????
shaun (england)
Old Dec 30, 2010 | 06:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
actually in NJ, you can swap any engine that was available in the platform in question, from the model year of the car and newer. So technically a 4th gen is still a fbody, so a ls1 can be "legal", and since NJ has ditched inspections other than tail pipe, as long as its running clean enough, and engine will pass flying colors.
Old Dec 30, 2010 | 06:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by z28m8
hi guys,
shaun (england)
engine and gearbox (trans) can be removed and installed assembled, however a leveler system for the hoist is a good idea to allow you to angle the assembly up and down as needed to clear the corssmembers and radiation support
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
84redta
Sep 19, 2015 09:58 AM
Doobie52
Sep 11, 2015 06:19 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
