5.0 truck engine fit into 91 camaro?
Old Jan 3, 2011 | 02:56 PM
jeremy197927's Avatar
I recently bought a 89 peice of junk camaro that had a 5.0 in it so I can swap it for my 3.2 V6 in my 91. After pulling the engine out and breaking it down, I decided to run the engine code. It comes back to a 88 chevy truck. My plan is to make this into a carb'd engine. Will this still work with the camaro parts and transmission? How much more difficult will this make it? Will it be easier just to find an actual camaro block or heads? Or does it really matter? Any kind of advice will be helpful.
Old Jan 3, 2011 | 02:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 5.0 truck engine fit into 91 camaro?
Originally Posted by jeremy197927
Will it be easier just to find an actual camaro block or heads? .
No , it is still a SBC
Old Jan 3, 2011 | 03:09 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
The truck block will work just fine. All Gen 1 SBC's are the same externally. It will bolt into the car just fine as long as you use the V8 engine mounts.
It will not bolt to your V6 transmission however. The bolt pattern for the bellhousings are different between the F-body V6's and an SBC
Frozer!!!
Jan 19, 2024 04:55 PM
Wvcamaro
Sep 4, 2015 08:38 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
