Installing engine with Hedman Shorties attached
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I'm putting my 350 in tommorow, 1978 block, Thirdgen 083 heads, and I'm using the Hedman Shorty headers.. I've done measurements and it's going to be within... 1/4" on each side, I measure 28 1/2" while the 305 that came out with the manifolds was about.. 25 3/4"..
Has anyone installed their engine with the short headers on, or should I take them off?
Re: Installing engine with Hedman Shorties attached
Take em off.
Won't work with em on. Not in any production chassis I know of.
Lay em in the engine bay, lower the engine, and as the engine appoaches the right spot, lift em up and bolt em on.
Engine: 2004 LQ4
Quick and to the point, thank you, these are quite... interesting to install on a stand, I'm sure it's going to be wonderful to do after a few bottles of MGD in the car..
You don't put the bottles in the car, you know; you put them in the technician.
The more bottles, the more interesting. Enjoy the ride!!
Transmission: 4L80E/4L80E
I installed & pulled both the 305 and 350 with Hooker shorties installed. Much easier than trying to install the headers with the engine in the car, particularly since I also installed the spark plugs before stabbing the engine. I don't imagine it would be much if any different with Hedman shorties.
I didn't have to.
If you click on my vBGarage, there is a pic of the engine and trans ready to be stabbed, with the headers installed.
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
i had shorties that were really close to it, but to install them i had to remove just the shaft in the engine bay
Engine: 2004 LQ4
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
I pull and installl mine with SLP Shorties, drops right in, close, but in, all the time
Engine: 2004 LQ4
Yea, you have to take them off, it didn't want to fit with them on..
I have a 91, and it was getting hung up on just about everything..
I had to remove the drivers side header. Once I did, the engine/tranny dropped in easily. With the hoist still attached it's a piece of cake to re-install the drivers side header.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I would leave the passenger side header on and remove the drivers side header as it makes the installation much easier. Also it is much easier to install the drivers side header when the motor is in the car.
Yea that, the pass side is a mo bear when the motor is in, but I get mine in and out with them installed Thread
