stupid question but just checking
Old Mar 21, 2011 | 07:42 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
found a pretty good deal on a 350 but its out of a pontiac. Im 99% sure it will still bolt right up to my 700r4 but just wanna check before i buy it.
Old Mar 21, 2011 | 07:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: stupid question but just checking
What year Pontiac? Pontiac stopped making their own motors in the late 1970's.
Old Mar 21, 2011 | 07:49 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
A Pontiac what? Strato Chief?
If it's a third gen 350, it will work.
Old Mar 21, 2011 | 07:54 PM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
better double check old ponty motors had different paterns than smallblock chevys
Old Mar 21, 2011 | 07:58 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
its out of a 69 according the numbers i pulled off the back of the motor.
Old Mar 21, 2011 | 09:33 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I'm 99% sure anything pre 72 has a different bell housing pattern.
Old Mar 22, 2011 | 05:13 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
A 350 in 1969 Pontiac will most likely be a Pontiac engine in which case the bellhousing will be different. But some of those old Pontiacs had Chevy engines in them. Easy way to tell is Pontiac has an aluminum timing cover, Chevy uses stamped cover and the water pump attaches to the engine at two points on either side of the cover.
Old Mar 23, 2011 | 03:24 PM
spudz's Avatar
if its a pontiac 350 it has a different bell housing bolt pattern and will NOT bolt to your 700r4. If its a chevy 350..... it WILL bolt to your trans.
Cleotiz
Jan 6, 2018 08:56 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
