oil pan delema
Old Apr 3, 2011 | 06:54 PM
JAKES1963's Avatar
Car: 1992 camaro z28
Engine: 305tpi
Transmission: 5speed
oil pan delema
anyone know of any oil pans that are 6qts,driverside dipstick,1pc rms,that are 383 stroker friendly. still using y pipe and headers and y pipe will not fit with kicked out pans[7qts]cant seem to find right combo.also can i just cut into the 7qt pan i have to accomadate for y pipe ?motor has high volume pump. thanks
Old Apr 3, 2011 | 07:14 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: oil pan delema
you should be able to cut the pan and reweld it. Not sure what a 97 tahoe uses for a pan but it cleared my stroker crank with no problems. If you want to keep the pan then cut it and reweld. If you change to a smaller pan then replace the high vlume pump aswell
Old Apr 5, 2011 | 08:09 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: oil pan delema
How do you have a driver side dipstick and a 1pc Rear main seal?
Old Apr 5, 2011 | 08:14 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: oil pan delema
Aftermarket pan probably.
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
