detent cable bracket
Old May 12, 2011 | 10:28 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Short of a junk yard where can I find one. Car was a tpi, now has a carbureted 327. The braket I have on it now works good for throttle cable, but my detent cable angles from brakett to carb. Carb shop says I need one from a camaro
Old May 12, 2011 | 10:29 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: detent cable bracket
What carb?
Old May 12, 2011 | 10:45 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Quadrajet. The bracket I have now mounts to manifold.
Old May 12, 2011 | 11:37 AM
Car: 1992 RS
Engine: Carbed 350
I use http://www.summitracing.com/parts/EDL-8030/ ... it's adjustable, but I had to modify it a bit by drilling a few holes to extend the bracket for the TV cable a bit closer to me Edelbrock carb. It also mounts to manifold - but summit does have some that mount to the carb. Edelbrock makes another one that is not chrome but same design, about $15 cheaper.
Old May 12, 2011 | 11:49 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Do you have a pic of it installed. Also can you use cruise control with it
Old May 12, 2011 | 12:51 PM
Car: 1992 RS
Engine: Carbed 350
Don't remember on the cruise - don't see why not - I removed all my cruise control stuff. Here's pics:
Attached Thumbnails detent cable bracket-tvbracket1.jpg   detent cable bracket-tvbracket3.jpg
Old May 12, 2011 | 02:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For the record, TH700R-4's don't have a "detent" cable. They have a "throttle valve" cable.
The difference is significant.
Old May 12, 2011 | 03:50 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Do you know where I can get the correct bracket??
L0tuS
Oct 4, 2015 08:07 AM
dbrochard
Sep 25, 2015 04:56 PM
///DAN///
Sep 25, 2015 02:15 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
TheTraut88
Sep 11, 2015 05:16 AM
