Motor Mount Clamshells
Old May 17, 2011 | 04:06 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Hey I just got some clamshells for my engine but I have a couple of questions about them. First I don't have any bolts to bolt them to the engine. What size will I need? And second, they seem very similar but there are minor differences. Does it matter which one goes on which side? Oh by the way they are 3rd gen V8 motor mount clamshells and they are getting bolted to an LT1.
Old May 17, 2011 | 08:54 AM
Guest
Guest
Posts: n/a
Re: Motor Mount Clamshells
I hope someone will correct me if I'm mistaken, but it seems plausible that they are different to slightly offset the engine toward the passenger side, for more steering linkage clearance.
Old May 17, 2011 | 10:06 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Yes you are correct, it moves the motor left to right about 1/2 inch. The passenger side mount is 039436. Driver side is a longer number, dont know it off the top of my head.
I would think any bolt would be fine aslong as its a heavy grade bolt and fits the hole
Old May 17, 2011 | 09:29 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
driver side is like 140 something something something...
Old May 19, 2011 | 07:25 AM
Guest
Guest
Posts: n/a
Are we sure it's 1/2"?
I just got my new Moroso 62510 mounts and 62610 pads, and the mount parts, which replace the clamshells, are identical for both sides. The pads, which replace the rubber parts, may be 1/8" difference, but sure aren't 1/2".
Old May 19, 2011 | 08:56 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
1/4-1/2......I had issues with header clearance on frame rail. When I had it reversed
Old May 19, 2011 | 10:33 AM
Guest
Guest
Posts: n/a
So if it's 1/4" off center, then swapping sides should be a total movement of 1/2" for your experience.
Old May 21, 2011 | 08:13 AM
Guest
Guest
Posts: n/a
Last night, putting the new Morosos in, I realized we have it backwards. The valley of the crossmember is not symmetrical. It has a wider shelf under the steering linkage, beside the driver's-side coil spring. So the mounts offset the engine towards the driver's side. The net result is still a bit right of center, however.
Old May 21, 2011 | 10:52 AM
1 GTA's Avatar
Car: 1988 Trans Am GTA
Engine: Twin Turbo-Charged, Intercooled SBC
Transmission: Reverse Manual TH400
Axle/Gears: Aftermarket 9-Inch, 3.50 Gearset
The Moroso pad mounts (62610) are stamped DL (driver/left) and PR (passenger/right).
Old May 21, 2011 | 12:22 PM
Guest
Guest
Posts: n/a
Yeah, I guess I should have mentioned that in my post. Thanks.
Old May 22, 2011 | 11:58 AM
Guest
Guest
Posts: n/a
I got some pics to show the differences
Old May 22, 2011 | 12:00 PM
Guest
Guest
Posts: n/a
oops, these next pics didn't show up as expected. I'll re-try soon.
Old May 27, 2011 | 10:42 PM
caffeine's Avatar
Engine: 3500T
The numbers on my clamshells are 33497 and 14039436. Any idea which side is which?
Old May 28, 2011 | 05:36 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
3349 is passenger side, 140 is driver....it was stated a few posts up...
Old Jun 27, 2011 | 02:17 PM
caffeine's Avatar
Engine: 3500T
140... Is definitely passengers side; I just installed my engine and it only fits one way, especially since I'm using solid motor mounts. And I tried both ways to be sure.
Old Jun 27, 2011 | 07:27 PM
Guest
Guest
Posts: n/a
I didn't know there were any solid mounts for the stock clamshells? Are those identical, or marked for which side they go on?
I do know you can't mix and match stock parts with the Moroso parts.
Old Jun 27, 2011 | 08:40 PM
caffeine's Avatar
Engine: 3500T
I'm using the stock clamshells with solid frame mounts from spohn. I bought them with a k-member but I do think they also work with the stock k-member.
Old Jun 27, 2011 | 10:51 PM
Guest
Guest
Posts: n/a
Well, I just learned something new. Thanks for the edumacation.
Old Jul 16, 2011 | 08:06 PM
3rdgenfamily's Avatar
Car: 91' Z28
Engine: 383 TPI, 2-305 TBI, 305 TPI
The stock OEM mounts put them off to the passenger side. Why?
Old Jul 21, 2011 | 03:36 PM
Car: 91' Z28
Guess that's why 14039436 has LSP stamped on the inside of the bracket.....oh wait.....could that possibly mean Left Side Passenger?
Old Jul 21, 2011 | 03:38 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Would say driver side
Old Jul 21, 2011 | 03:40 PM
Car: 91' Z28
No wonder so many people mess this up........140 has LSP stamped right on it on the inside. It is there to let you know to put that mount on the Left Side Passenger. I know that left depends on where you are standing but the P is for passenger side.
Old Jul 21, 2011 | 03:54 PM
caffeine's Avatar
Engine: 3500T
That's weird because in my GM manual when it says left side that's the driver's side (as if you were sitting in the car).
Old Jul 21, 2011 | 04:51 PM
Car: 91' Z28
I here you. That must be why there is much confusion on this. The OEM stamp is a Large L sp sitting on the L maybe just Side Passenger don't know but if you swap them your engine will be crooked is sh*# if you get it in at all.
Old Jul 21, 2011 | 05:51 PM
0pyders's Avatar
I have 140 on the driver side with headers and everything fits/looks fine..
Old Aug 16, 2011 | 09:01 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My new motor is sitting lower on the drivers side. Could this be my problem since I put in new polyurethane mounts?
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
