305to 383 swap
Old May 22, 2011 | 09:58 PM
lionsfb57's Avatar
Car: 87 iroc z
305to 383 swap
I'm going from a 305tpi to a 383. What do I need to do with the cars computer? Get a 5.7 one? Or get this one flashed or something somehow
Old May 23, 2011 | 10:29 AM
lionsfb57's Avatar
Car: 87 iroc z
Re: 305to 383 swap
also will the tpi intake fit on the 383?
Old May 23, 2011 | 11:28 AM
bduffey723's Avatar
Car: not a camaro anymore
Re: 305to 383 swap
you will have to get the 350 brain box. ive never had tpi but im pretty sure u can use that tpi.. larger injectors and throttle body i would imagine u will need as well though
Old May 23, 2011 | 01:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
To get it to start and run, you probably won't have to do anything with the computer. To get it to run its best, you will need to tune the computer.
Whether or not your TPI base fits depends upon what heads the 383 has. Most likely, stock TPI hardware will choke a 383 (if it doesn't choke the 383, something is seriously wrong with the 383).
Old May 23, 2011 | 03:15 PM
lionsfb57's Avatar
Car: 87 iroc z
Re: 305to 383 swap
I have an edelbroxk intake and throttle body already. I'm not sure what type of heads are on the engine tho
Old May 23, 2011 | 03:26 PM
five7kid's Avatar
What about runners? Has the plenum been ported?
Old May 23, 2011 | 03:29 PM
lionsfb57's Avatar
Car: 87 iroc z
Re: 305to 383 swap
I don't believe so. And What about the runners?
Old May 23, 2011 | 03:30 PM
lionsfb57's Avatar
Car: 87 iroc z
Re: 305to 383 swap
And I'm goin to buy a bigger siZe injectors. What size you think would be good? 22 lb right now
Old May 23, 2011 | 03:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 305to 383 swap
You need to know what is in the 383 before doing anything to the computer. Same with injectors. Being an 87 it is a MAF sensor car. All you need to do is swap in the 383 motor with the TPI intake for now, and all the sensors, rewire it up and find a 350 TPI MAF sensor factory chip/memcal.
You will need to tune this thing with custom chip but it may run/start just fine depending on whats done to the 383. If its a wild setup with big cam/high compression and big heads, it may not run well on stock chip If you swap injectors and try to run it on a stock chip, it likely wont run. If its a wild setup it may want 36lb injectors. TPI builds with lower hp and lower rpm range typically only need 24-30lb injectors. I'd buy 30's for room down the road unless your talking about a very mild 383 here.
If you can get a 89 350 TPI chip and dont plug in the cold start "9th" injector if you have that on your setup.
To feed a 383, its best that the base is ported out to the max and the runners be of a larger tube size like AS&M, ACCEL big tube or TPIS large tube runners. Siamesed SLP's are good too. Anything aftermarket is better than stock
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Cameeeero
Sep 18, 2015 04:00 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
