305 TPI swap to big block
Old Jun 25, 2011 | 11:18 AM
RollinLoud's Avatar
Car: 1986 Camaro IROC
Engine: 5.0 V8 TPI
Transmission: manuel
Will a GM big block fit in a 1986 Iroc Camaro? And if not what will have to be done to make it fit?
Old Jun 25, 2011 | 02:47 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 305 TPI swap to big block
short answer: yes. long answer: yes, with a lot of modifications.
Old Jun 25, 2011 | 07:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Read the sticky at the top of the forum on doing a BBC swap then ask questions.
Old Jun 26, 2011 | 09:39 AM
RollinLoud's Avatar
Engine: 5.0 V8 TPI
Ok, so I am looking to put a 454 HO in it. Will I just have to get smaller fluid containers or will I have to do body modifications?
Old Jun 26, 2011 | 09:45 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
If you think your coolant fill tank and windsheild washer tanks are going to be a problem, then this might be too big a project for you.
Old Jun 26, 2011 | 10:14 AM
travis401's Avatar
Car: 91 Camaro RS
You have to do a lot more than change fluid tanks....and most likely you wont be able to cram a BB under the stock hood.
Old Jun 26, 2011 | 10:26 AM
RollinLoud's Avatar
Engine: 5.0 V8 TPI
Replacing fluid tanks is okay, I can do that, and I will be getting a new hood to fit the engine. I am asking if body mods will need to be done and what wires and things I will need to keep from the 305 tpi for the 454 HO
Old Jun 26, 2011 | 10:58 AM
92 BBC Z's Avatar
Its still a vauge question. Read the 'sticky's' like AlkyIROC said, then ask questions. If "body mods" are refering to the front fender wells, then no 'mods" needed. As far as wiring goes, pretty much anything connected to the tpi's computer is a wash.
Old Jun 26, 2011 | 11:26 AM
Guest
Guest
Posts: n/a
The sticky seems to have issues. Try this:
https://www.thirdgen.org/forums/engi...-454-swap.html
Old Jun 26, 2011 | 11:31 AM
travis401's Avatar
Car: 91 Camaro RS
I would be saying to check the sticky as well, but the links in it arent working so its not a whole lot of help. basically youll be getting rid of nearly everything related to your 305 and replacing it all with BB specific parts. lots of mods. this is not a project for someone with no engine swapping experience or wiring experience or fabing experience. do your self a favor and buy a SB 350. much easier to swap in for the beginer and still a VAST imporvement over the 305
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
