1991 Firebird 3.1L V6
Old Aug 4, 2011 | 12:54 PM
Firebird_305's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L TBI
Transmission: Automatic
Hey guys! Is it at all possible to go from the 3.1L fuel injection to a carburated engine? I've been looking and see that it is a huge hassle to swap a V6 to V8. Just really curious what it takes to get rid of the fuel injection all together and put a carb in it.
Thanks!
Dustin
Old Aug 4, 2011 | 03:26 PM
Guest
Guest
Posts: n/a
Re: 1991 Firebird 3.1L V6
The '82-'84 2.8 had a computer-controlled carb. Edelbrock makes an intake manifold that will take that or a Holley 390, but you still have no choices for a non-computer distributor. Plus this idea isn't even technically legal, though you may get away with it.
Old Aug 4, 2011 | 04:17 PM
AmorgetRS's Avatar
Why would you want to go backwards like that? The 3.1 has a pretty good fuel injection system.
Old Aug 5, 2011 | 10:23 AM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I think some s10's had 2.8 tbi and older ones had carb set ups.You might be able to take parts off one of thoughs.
Old Aug 23, 2011 | 03:02 PM
K2000's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6
the 3.1 is only good as a daily commuter. But im gettin tired of it so probably ill look for a cheapie 350 from a 96-98 chevy silverado with vortec heads, add a carburetor and work my way up from there
Old Aug 23, 2011 | 04:01 PM
AmorgetRS's Avatar
Buy another V-8 F-body and go from there. The time and cost of swapping the V-8 into the 6 is NOT worth it.
Old Aug 23, 2011 | 06:06 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Why is it not worth it? You have to do extra work, yes i agree. But the price tag of buying a whole new car vs odds and ends to do a v6 to v8 swap dont compare in my opinion, This is if you have a nice v6 shell.
-New front brake lines
-New motor mounts
-Fuel Regulator ( ill have one from my swap for sale )
-New Serpentine setup from a v8 Fbody, or a 4.3l s10
-Gonna need a trans, but can find them used under $500
-Most likely a new radiator
All those parts you can find at a junkyard, minus the regulator
Think that sums it up. Notice i left out the v8 suspension, because you dont need it for a daily driver! v6 suspension rides alot better then v8 anyways, if your not planning on drag racing or circle tracking the car
If your car is in rough shape, then yes, maybe i would buy a v8 car and do the swap.
Old Aug 23, 2011 | 06:14 PM
AmorgetRS's Avatar
Engine + trans + misc cost almost as much as a running V-8 Thirdgen. Factor in what you gain from selling the V-6 as a whole car and you are WAY ahead. And it involves almost none of the work.
Old Aug 23, 2011 | 06:48 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
-New motor mounts
the suspension is not going to ride better with the v8 on top of it
Old Aug 23, 2011 | 06:51 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
I guess everyone has there own opinions. I have done 2 v6 to v8 conversions. One in a camaro, and recent in a firebird. They ride alot better then the v8 camaro I just bought. And notice I just said ride. Not talking handling and corning or anything
Old Aug 28, 2011 | 08:49 PM
Pocket's Avatar
Car: 91 Trans Am
So it rides like a Cadillac and rolls in the corners. Great trade off
Face it, engine swaps are not cost effective. Im a HUGE advocate of the LSx engines, but swapping on is NEVER as inexpensive as buying a car with one already installed. So you'd tear down a dependable 3.1, sure its slow, but you'd replace it with a dinosaur of a 350? Really?
Add it up, a few grand to do the swap, rides smooth, but cant corner. Gas mileage is mid teens if that, value hasnt gone up, in most cases gone down. Probably run terrible because if you cant keep a V6 running, no chance you'll know how to tweak a cold natured carb
I dont see the upside. Sell the V6 and buy a V8 if it bothers you that much. Lots and lots pop up FS on these forums and at your local craigslist for $1500 or less, road worthy. Maybe save up your pennies a few more weeks and drop the $3-4k on a nice one because thats about all a 3rd gen will ever be worth. You'd be fooling yourself if you think you can do an engine swap for that much
jhawkeye
May 25, 2022 06:33 PM
evan555222
Sep 20, 2016 02:51 AM
deracer
Apr 11, 2016 12:04 AM
wild1
Aug 27, 2015 09:01 AM
evan555222
Aug 22, 2015 07:14 PM
