New to this need some help
Old Aug 18, 2011 | 12:27 PM
88fbody305's Avatar
Hey guys im new to the whole chevy v8 deal and i really like it so i went and bought a 350 5.7 small block, the block is perfect i already ordered a kit from summit racing with forged pistons the whole nine yards, im good with everything that has to deal with engines now the swaping part is what gets me, i have a 88 f body camaro it currently has the 2.8 with a 5 speed, everything is as stock as it can be, by now you guys get my idea , i wana drop the 350 in it, what do i need does the 350 would bolt right in can i use the stock transmission, can i use a t56, do i have to run any wires, new computer or somethin to it (I want it fuel injected) i dont like carb... i really need you guys help one of my freinds told me about the site that is really helpful and i need a lot of help, thank you guys a lot im gona be checking this every day and everything will help again thank you
Old Aug 18, 2011 | 12:36 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: New to this need some help
Welcome! Lots of good threads out there on this already. If you use the search that should cover 95% of your questions.
You're going to need a 350 ECM (computer) and a harness for a V8. I assume you're wanting to go plain TPI setup not something like a LT1 or LS1. Your T5 won't work on a V8 without extra work and even then most people believe it's not the best idea to convert them.
3.1 to 5.0 swap:
https://www.thirdgen.org/forums/engi...3-1-5-0-a.html
2.8 5 speed to a 350 swap:
https://www.thirdgen.org/forums/engi...eed-2-8-a.html
https://www.thirdgen.org/forums/engi...5-2-8l-v6.html
https://www.thirdgen.org/forums/engi...sion-help.html
Also keep in mind there isn't much different in the intakes of 305 vs 350 (just injectors). In the late 80s they converted from a cold start injection type. In '90 they started using Speed Density vs MAF sensors.
Old Aug 18, 2011 | 12:41 PM
88fbody305's Avatar
THXXXXXX a lot bro thanks for the quick response two
Old Aug 18, 2011 | 12:49 PM
88fbody305's Avatar
what about the cross members and steering rack would the 350 bolt right in???????
Old Aug 18, 2011 | 12:56 PM
88fbody305's Avatar
n how hard would it be to be fuel injected like a ls1 or lt1 just for facts
Old Aug 18, 2011 | 12:58 PM
Engine: 383 SBC
Need to use different mounting area for the V8 vs the V6 on the K member.
Here check out this thread:
https://www.thirdgen.org/forums/engi...swap-read.html
And here's a v6 to v8 swap story:
https://www.thirdgen.org/forums/engi...son-v6-v8.html
Anything can be done with enough time and money. You've already bought a block and pistons so you're kinda limited by that now. They [LS1s] use a different engine design all together.
See this:
http://en.wikipedia.org/wiki/Chevrol...and_LS_engines
Old Aug 18, 2011 | 01:11 PM
Engine: 383 SBC
Anyways hope it works out for you. It'd be a real bitch to pull the 350 apart and find out it's already 30 over bored or something and the new pistons don't fit because of it.
Old Aug 18, 2011 | 05:59 PM
88fbody305's Avatar
They wouldnt sell a kit for it like the one for the ls1 swap into the f body????????
Old Aug 18, 2011 | 06:20 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
sell what kit? LS1 is a totally different engine then a Gen1 350.
Find a t5 trans out of a v8. You also need to find v8 motor mounts, If your block doesnt have a serpentine system or v belt system your gonna need to find one also, your v6 stuff doesnt work with the v8.
You need to re-route your front brake line as they are in the way of the v8 motor mounts, so you mise well just put new ones in while you can.
The stock fuel pump should be enough as MPFI pumps alot out and our good pumps.
People will say you "HAVE" to change your front shocks to v8, i call BS. Yes the v8 weighs more then a v6 but i have done the swap twice and the car handled just fine driving on the road. Note i said driving, not racing
just a few things needed to be done, am old school, cant help much with the FI you want to run
Old Aug 18, 2011 | 06:25 PM
88fbody305's Avatar
awsame bro thx so just by gettin the mounts it would fit???? and doin everything else u said
Old Aug 18, 2011 | 06:28 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
The cars are all the same, v6, 5.0, 5.7. Only difference is v6 mounts are placed differently. You may need a v8 harness if your going tpi lilke others said but I have no clue
Old Aug 18, 2011 | 06:31 PM
88fbody305's Avatar
ok cool thanks a lot n one more random thing if i take the block to a machine shop they would knoiw if is bored right????
Old Aug 18, 2011 | 06:33 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Yes
Old Aug 19, 2011 | 01:58 AM
88fbody305's Avatar
What can it be used for the wire harness of the camaro 2.8
Old Aug 19, 2011 | 02:33 AM
Engine: 383 SBC
I have no idea but due to the fact it's going to be a different intake and have 2 more injectors it would be easier just to get the harness when you snag the 350 ecm. Check out ebay, most of the time you can get tpi, distributor, ecm, and harness as a packaged deal on there.
Where exactly did you get this block?
Old Aug 19, 2011 | 02:56 AM
88fbody305's Avatar
Ok that sounds really good is gonna be 350 with t56
Old Aug 19, 2011 | 05:05 AM
88fbody305's Avatar
I got it off a guy that parted out a 88 corvette so imguessing is a l98???? maybe
Old Aug 19, 2011 | 06:35 AM
88fbody305's Avatar
I
Old Aug 19, 2011 | 09:16 AM
88fbody305's Avatar
ok now i really wana know what block is this, this all the info that i could get out of it
V0715ZDF
4810207
CDF
207
HELP PLZZZZZZZ
Old Aug 19, 2011 | 09:38 AM
88fbody305's Avatar
casting number 4010207
Old Aug 19, 2011 | 09:41 AM
88fbody305's Avatar
is a 350 from year 80 to 85 it comes up in this page http://outintheshop.com/faq/casting/castings2.html
Old Aug 19, 2011 | 03:33 PM
Engine: 383 SBC
Yep I'm guessing 80 to 85 350... atleast that's what it started as.
Old Aug 23, 2011 | 06:05 PM
88fbody305's Avatar
What type of heads would bolt on the 350 block and here are the plans for the build
350 block bored .30 over
summit racing 350 rebulild kit with forged pistons flat top with 4 valve reliefs( kit brings everything expect the cam and lifter)
stage 2 connecting rods
havent decided with cam to use in which arpm range im thinkin voodoo dont know which rpm thogh(ADVISE WOULD BE HELPFUL)
heads havent decided which one to use that would bolt to Weiand Stealth Ram Intake Manifold TPI from hawksthirdgenparts.com(HELP ON THIS)
at least 58mm thottle bodie
60-70mm turbo
t56 transmission
rear end not so shure what to put on
OEM wire harness with poss tuned ECM
thats what i got so far any advice would help
Old Aug 23, 2011 | 06:10 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Not all that experienced but you might want domed pistons to lower the compression, i believe flat tops raise the compression, you would want to be 8:5:1 or 9 on compression to run boost.
Heard voodoo cams are great for making noise, but suck making power. Would concider calling up some companys, tell them what your plans are, and have them custom grind one
Old Aug 23, 2011 | 06:13 PM
88fbody305's Avatar
cool and what about the heads and the manifold what would you recomend on that
Old Aug 23, 2011 | 06:23 PM
88fbody305's Avatar
also one very important thing the block is a 2 bolt main
Old Aug 23, 2011 | 06:26 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Not sure about those intakes, whatever head you choose ( I would think 195cc or better) make sure ot wont raise your compression too much.
2 bolt block should hold the power, unless your thinking 600+hp
Old Aug 23, 2011 | 06:40 PM
88fbody305's Avatar
im good close to the 600 but not 600 plus and thats the only step back that im having you wont know what heads would be good for it
